[Geomoose-users] multiple layer selection/thematic layers problem
Lee Meilleur lee.meilleur at gis.leg.mn
Wed May 7 12:56:12 EDT 2008
A couple of things.  First, Brad Neuhauser from Secretary of State wrote some nifty code for a multiple layer selection pulldown.  You can see it at the link below.  The map is being used for a bill that's up in one of the House Committees (hf3293 if you're interested).  For some reason, the thematic layers towards the bottom always draw on top of everything else, unless one spends the time to turn the layers off and on that are above the thematic layers.  Is there a way to make the map load and refresh so the layers always draw correctly?
http://www.gis.leg.mn/geomoose/hf3293/<http://www.gis.leg.mn/geomoose/hf3293/>
Thanks!
Lee Meilleur
LCC-GIS Office
Minnesota Legislature
100 Rev. Dr. MLK Jr Blvd.
55 State Office Building
St. Paul, MN 55155
651.296.0098  Fax: 651.297.3697
lee.meilleur at gis.leg.mn<mailto:lee.meilleur at gis.leg.mn>
http://www.gis.leg.mn<http://www.gis.leg.mn/>
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20080507/6f8f74ab/attachment.html
More information about the Geomoose-users mailing list
