[Geomoose-users] multiple layer selection/thematic layers
problem
Fischer, Brian
bfischer at houstonengineeringinc.com
Wed May 7 17:19:03 EDT 2008
Lee/Brad,
Very nice multiple layer pull down code. Do you want to contribute the
code and write a "How To" on the GeoMOOSE website?
As far as the layer ordering, there is a configuration setting in the
configuration.js file that is called MAP_MAPBOOK_ORDER. Do you have
this set to true or false? If it is set to false, change it to true and
it should get you what you want. If that doesn't work, what version of
GeoMOOSE are you running? It might be a bug. Let us know if you get it
working right.
There is a description about that setting at:
http://www.geomoose.org/moose/documentation/configuration-guides/configu
ration.js, go under the General Interface section.
-Brian
Brian Fischer
Houston Engineering, Inc.
Maple Grove, MN
(763) 493-4522
From: Lee Meilleur [mailto:lee.meilleur at gis.leg.mn]
Sent: Wednesday, May 07, 2008 11:56 AM
To: Fischer, Brian; Bob Basques; geomoose-users at lists.sourceforge.net;
'Brad Neuhauser'
Subject: multiple layer selection/thematic layers problem
A couple of things. First, Brad Neuhauser from Secretary of State wrote
some nifty code for a multiple layer selection pulldown. You can see it
at the link below. The map is being used for a bill that's up in one of
the House Committees (hf3293 if you're interested). For some reason,
the thematic layers towards the bottom always draw on top of everything
else, unless one spends the time to turn the layers off and on that are
above the thematic layers. Is there a way to make the map load and
refresh so the layers always draw correctly?
http://www.gis.leg.mn/geomoose/hf3293/
<http://www.gis.leg.mn/geomoose/hf3293/>
Thanks!
Lee Meilleur
LCC-GIS Office
Minnesota Legislature
100 Rev. Dr. MLK Jr Blvd.
55 State Office Building
St. Paul, MN 55155
651.296.0098 Fax: 651.297.3697
http://www.gis.leg.mn <http://www.gis.leg.mn/>
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20080507/d4a46eb4/attachment.html
More information about the Geomoose-users
