[Geomoose-users] Printing...
CoFIS web | www.cofis.info
coffee at uni-bonn.de
Thu Oct 16 04:46:13 EDT 2008
Dan,
I had a look at the fonts directory and the fontset.list. I cleaned up my fontset.list to
only contain fonts that are available in the fonts directory and checked my mapfiles for
the font types being used - and still get the error.
Dan Little schrieb:
> What you might need to try one of the following things:
> Step 1: Figure out what font is causing the error.
Is there a logfile for the printing service, where I can have a look at. Or can I create
one If there isn't by default?
Thanks,
Nils
> Step 2: Open the "fonts" directory in the maps directory that you are using, there is a file called fontset.list. This file relates the name of the font in the mapfile to the file of the truetype font on the filesystem.
> Step 3: Ensure that file is, in fact, on the file system, in the fonts directory.
> Step 4: If it's not, try adding it there, or if it is else where, use an absolute path to the TTF file.
> If you don't have the file, or cannot find it, let me know as I have them on my computer and can send it to you.
> ----- Original Message ----
>> From: CoFIS web | www.cofis.info <coffee at uni-bonn.de>
>> To: Dan Little <danlittle at yahoo.com>
>> Sent: Thursday, October 9, 2008 10:33:42 AM
>> Subject: Re: [Geomoose-users] Printing...
>> Dear Dan,
>> thanks for that hint.
>> One note specifically for Debian Linux and php5:
>> One needs to install dbase.so separately (no dbase.so in the Debian packages) as
>> described
>> here:
>> http://www.mattiasgeniar.be/php/how-to-compile-and-install-php-extensions-from-source
>> One having done this, I get the following error:
>> Warning: [MapServer Error]: msGetLabelSize(): Could not find/open font in
>> /srv/www/geomoose/production/php/print.php on line 247
>> Fatal error: Call to a member function saveImage() on a non-object in
>> /srv/www/geomoose/production/php/print.php on line 250
>> - no matter which version of fpdf I am using (/srv/www/geomoose/production/
>> corresponds to
>> /ms4w/apps/geomoose/htdocs). I guess this has to do with some font path
>> definition. Could
>> you - or anyone else - please give me a hint where to start looking for the
>> right path
>> setting?
>> Thanks,
>> Nils
>> Dan Little schrieb:
>>> Actually, if you open "Configuration.php" in the "php/" directory, line 25
>> allows you to specify the location of FPDF.
>>>> To: Dan Little
>>>> Cc: Jay Kapalczynski ;
>> "geomoose-developers at lists.sourceforge.net"
>> "geomoose-users at lists.sourceforge.net" ;
>> "Fischer, Brian"
>>>> Sent: Thursday, October 9, 2008 7:33:13 AM
>>>> Dear all,
>>>> I am using Debian Linux and got fpdf installed via aptitude.
>>>> Do I have to symlink the install location of fpdf to my geomoose/htdocs/php
>>>> directory or
>>>> do I have to put a completely new copy of fpdf into geomoose/htdocs/php?
>>>> Thanks,
>>>> Nils
>>>> Dan Little schrieb:
>>>>> Yeah, you've got to install FPDF. And, crap, we don't have any
>>>>> documentation for how to do it -- OF COURSE.
>>>>> We cannot redistribute FPDF with GeoMOOSE due to license restrictions
>>>>> with FPDF.
>>>>> Here's how to fix your problem:
>>>>> 1) Download FPDF from http://www.fpdf.org/?go=download get the latest
>>>>> zip file.
>>>>> 2) Go to /ms4w/apps/GeoMOOSE/htdocs/php
>>>>> 3) Create folder named FPDF
>>>>> 4) Extract all the files from the zip file you downloaded in step 1 into
>>>>> the folder you just created.
>>>>> From: Jay Kapalczynski
>>>>> To: "geomoose-developers at lists.sourceforge.net"
>>>>> ; "Fischer, Brian"
>>>>> Sent: Tuesday, October 7, 2008 1:47:50 PM
>>>>> Subject: [Geomoose-users] Printing...
>>>>> I was wondering if anyone knows about the printing….I am trying from out
>>>>> of the box and I get these errors./….
>>>>> Is there something I am missing?
>>>>> This SF.Net email is sponsored by the Moblin Your Move Developer's challenge
>>>>> Build the coolest Linux based applications with Moblin SDK & win great
>> prizes
>>>>> Grand prize is a trip for two to an Open Source event anywhere in the world
>>>>> http://moblin-contest.org/redirect.php?banner_id=100&url=/
>>>>> _______________________________________________
>>>>> Geomoose-users mailing list
>>>>> Geomoose-users at lists.sourceforge.net
>>>>> https://lists.sourceforge.net/lists/listinfo/geomoose-users
>>>> Nils Zierath
>>>> CoCE-Web Administration
>>>> Center for Development Research
>>>> Department of Ecology and Resource Management
>>>> Walter-Flex-Strasse 3
>>>> 53113 Bonn (Germany)
>>>> Tel.: +49 (0) 228 - 73-1793
>>>> FAX: +49 (0) 228 - 73-1889
>>>> E-Mail: nzierath at uni-bonn.de
>>>> Web: http://www.coffee.uni-bonn.de
>>>> http://www.zef.de
More information about the Geomoose-users
