[Geomoose-users] [mapserver-users] Points with hyperlinks
Matej
matej at matnet.net
Sun Sep 28 15:22:54 EDT 2008
Bob,
thank you for your reply. My current choice would be the Imagemap one. Could
you attach some short XML and other appropriate snippets to achieve it?
Actually I have a working .map file which creates my that content between
<map> and </map>, but I am looking for examples on how to include it into
GeoMoose, which anyways works perfectly.
Thank you for your help in advance,
Matej Serc
matej at matnet.net
----- Original Message -----
From: "Bob Basques" <Bob.Basques at ci.stpaul.mn.us>
To: <matej at matnet.net>
Cc: <mapserver-users at lists.osgeo.org>;
<geomoose-users at lists.sourceforge.net>
Sent: Friday, September 26, 2008 2:18 PM
Subject: Re: [mapserver-users] Points with hyperlinks
Matej,
I'm copying this reply to the GeoMoose Mail list.
Are you interested in working the process as a pick option or query service,
where you pick a point on the map and the server responds with a new window
containing the link, or do you want to use a Imagemap, where all the links
available for a particular view are downloaded at once and you can open up a
new window by picking from active areas in the map?
GeoMoose can go both ways. I use the ImageMap process quite extensively,
since I can send some basic metadata like info down to the client in short
form, and let the user decide it they want to see more. I can also include
more than on link this way and let the user decide which they want to open
up.
The Query Service is good though if you know you are always going to want to
look at the result in a new page no matter what.
bobb
>>> "Matej" <matej at matnet.net> 09/26/08 4:52 AM >>>
Hello,
thanks everyone for help and suggestions so far ... I am using GeoMoose as a
client and I have some problems implementing it. Does someone have a working
XML Mapbook code snippet for "including" mapfiles into the GeoMoose? It
works directly when I call mapserv from URL anyway ...
Thanks everyone,
Matej Serc
matej at matnet.net
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
More information about the Geomoose-users
