[Geomoose-users] Multiple Parcel Select
Nelson Soto
NSoto at plotplans.com
Mon Sep 29 10:56:54 EDT 2008
The error seems to be the same:
Error on line 692 of GeoMoose.js:
http.send(postData);}
I'm an unsure if I should continue to work with 1.4 or wait until 1.6; I
am sort of hanging in limbo as I don't really want to have to port the
code over as I am essentially deciding whether to port from 1.2 to 1.4
vs. 1.2 to 1.6.
I'm also unsure of the features of 1.6 as I know the documentation
hasn't been updated yet so until then I will postpone as long as
possible.
Thanks Brian.
From: Fischer, Brian [mailto:bfischer at houstonengineeringinc.com]
Sent: Friday, September 26, 2008 4:11 PM
To: Nelson Soto; Nelson Soto; geomoose-users at lists.sourceforge.net
Subject: RE: [Geomoose-users] Multiple Parcel Select
By replacing the GeoMOOSE.js and main.js file that might fix the menu
issue in IE7. I've attached it for you to try.
Brian Fischer
Houston Engineering, Inc.
Maple Grove, MN
(763) 493-4522
Sent: Friday, September 26, 2008 6:49 AM
To: Fischer, Brian; Nelson Soto; geomoose-users at lists.sourceforge.net
I'm actually making good progress on it, but was developing on 1.2 so I
needed a newer version to accept the http parameters that I wanted to
provide. I then upgraded to 1.4 and the next day 1.6 was sent out but it
unfortunately was not working for IE7 so for now I have stopped
developing but yes, it does require some improvising.
Sent: Thursday, September 25, 2008 10:45 PM
To: Nelson Soto; geomoose-users at lists.sourceforge.net
Subject: Re: [Geomoose-users] Multiple Parcel Select
Nelson, I don't believe this is possible with any services we have setup
now in GeoMOOSE. I think you would need to write your own PHP mapscript
service to do this. I think the select.php might serve as some example
code to get started.
Maybe others have some other ideas.
-Brian
From: Nelson Soto [mailto:nellyfromma at gmail.com]
Sent: Monday, September 22, 2008 2:34 PM
To: geomoose-users at lists.sourceforge.net
Subject: [Geomoose-users] Multiple Parcel Select
Has anyone had any success implementing a multi-parcel select into
GeoMoose. I know you can return multiple search results but what I'd
like to acheive is searching for say a particular type of matching
criteria, say all parcels owned by a certain individual, and have them
all light up. I don't want someone to do this for me just an idea of how
they wenty about implementing it. Will I need to develop my own service
as a substitute for using mapserver's nquery? I notice the search uses
nquery too but it only creates a list of results, it doesn't select
them... Hopefully someone can offer me a good way to approach this.
Thanks,
Nelson Soto
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20080929/03aa1170/attachment.html
More information about the Geomoose-users
