[Geomoose-users] Multiple Parcel Select
Dan Little
danlittle at yahoo.com
Mon Sep 29 13:58:20 EDT 2008
Nelson,
Can you post the service definition?
----- Original Message ----
To: "Fischer, Brian" <bfischer at houstonengineeringinc.com>; Nelson Soto <nellyfromma at gmail.com>; geomoose-users at lists.sourceforge.net
Sent: Monday, September 29, 2008 9:56:54 AM
Subject: Re: [Geomoose-users] Multiple Parcel Select
The error seems to be the same:
Error on line 692 of GeoMoose.js:
http.send(postData);}
I’m an unsure if I should continue
to work with 1.4 or wait until 1.6; I am sort of hanging in limbo as I don’t
really want to have to port the code over as I am essentially deciding whether
to port from 1.2 to 1.4 vs. 1.2 to 1.6.
I’m also unsure of the features of
1.6 as I know the documentation hasn’t been updated yet so until then I
will postpone as long as possible.
Thanks Brian.
[mailto:bfischer at houstonengineeringinc.com]
Sent: Friday, September 26, 2008
4:11 PM
To: Nelson Soto; Nelson Soto;
Subject: RE: [Geomoose-users]
By replacing the
GeoMOOSE.js and main.js file that might fix the menu issue in IE7. I’ve
attached it for you to try.
Brian Fischer
Houston Engineering,
Inc.
Maple Grove, MN
(763) 493-4522
Soto [mailto:NSoto at plotplans.com]
6:49 AM
To: Fischer, Brian; Nelson Soto;
I’m actually making
good progress on it, but was developing on 1.2 so I needed a newer version to
accept the http parameters that I wanted to provide. I then upgraded to 1.4 and
the next day 1.6 was sent out but it unfortunately was not working for IE7 so
for now I have stopped developing but yes, it does require some improvising.
Brian [mailto:bfischer at houstonengineeringinc.com]
Sent: Thursday, September 25, 2008
10:45 PM
To: Nelson Soto;
Nelson,
I don’t believe this is possible with any services we have setup now in
GeoMOOSE. I think you would need to write your own PHP mapscript service
to do this. I think the select.php might serve as some example code to
get started.
Maybe
others have some other ideas.
-Brian
Soto [mailto:nellyfromma at gmail.com]
Sent: Monday, September 22, 2008
2:34 PM
To: geomoose-users at lists.sourceforge.net
Subject: [Geomoose-users] Multiple
Parcel Select
Has anyone had any success implementing a multi-parcel
select into GeoMoose. I know you can return multiple search results but what
I'd like to acheive is searching for say a particular type of matching
criteria, say all parcels owned by a certain individual, and have them all
light up. I don't want someone to do this for me just an idea of how they wenty
about implementing it. Will I need to develop my own service as a substitute
for using mapserver's nquery? I notice the search uses nquery too but it only
creates a list of results, it doesn't select them... Hopefully someone can
offer me a good way to approach this.
Thanks,
Nelson Soto
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20080929/2cac9209/attachment.html
More information about the Geomoose-users
