[Geomoose-users] GeoMoose 2.0, Linux, and getmapbook.php
Brent Fraser bfraser at geoanalytic.com
Tue Aug 4 12:43:06 EDT 2009
Carrie,
   You can avoid getmapbook.php (see
http://www.geomoose.org/moose/howto/getmapbook.html) for the purposes of getting
GeoMoose up and running, but I'd recommend tracking down the PHP problem for a
long term solution (PHP is used for several advanced functions in GeoMoose):
1. make sure PHP is working OK on the server by executing php on the command line
2. check PHP scripting through the web server software (e.g Apache)
3. check correct installation of mapserver PHP libraries
   - there's a "test.php" script in the GeoMoose PHP directory
Best Regards,
Brent Fraser
Carrie Quast wrote:
> My IT person is having a bit of trouble getting GeoMoose 2.0 to work on
> a linux server-  the problem seems to be that it doesn't like the
> getmapbook.php.  He has updated all the PHP libraries on the server.  He
> thinks its either something in the getmapbook.php, or the linux PHP
> itself.  Has anybody else encountered a problem with Linux and PHP with
> GeoMoose 2.0, and found a solution to it?
> Thank You, Carrie Quast
> -Brown County GIS Specialist.
> Let Crystal Reports handle the reporting - Free Crystal Reports 2008 30-Day
> trial. Simplify your report design, integration and deployment - and focus on
> what you do best, core application coding. Discover what's new with
> Crystal Reports now.  http://p.sf.net/sfu/bobj-july
> Geomoose-users mailing list
> Geomoose-users at lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/geomoose-users
More information about the Geomoose-users mailing list
