[Geomoose-users] Limit Identify Result
Jessica Fendos
Jessica.Fendos at state.mn.us
Thu Aug 6 15:23:20 EDT 2009
Thanks Brent:
I was able to limit the identify result using this metadata tag in
Chameleon (another add-on to MapServer) so was hoping I can do the same
in GeoMoose.... Suggestions anyone?
Jessica
>>> Brent Fraser <bfraser at geoanalytic.com> 8/6/2009 2:10 PM >>>
Jessica,
I don't think "query_limit" has been implemented in Mapserver yet
(http://trac.osgeo.org/mapserver/ticket/2424). The only option I can
think of
is to do some PHP (or other scripting language) programming, similar to
GM's
select.php and limit the returned results there.
But you might want to ask the question on the Mapserver-users email
list.
Best Regards,
Brent Fraser
Jessica Fendos wrote:
> Hi list:
> I am using GeoMoose 1.6.1. I have several point layers (employers by
> industry) that I would like to display in the mapping interface. Due
to
> InfoUSA data restriction, I would like to limit the display of
records
> resulting from the "Identify" tool to 5.
> I added the following
> *METADATA
> "query_limit" "5"
> END*
> to this layer in identify.map (under maps_statedemo) and employer.map
> (under maps_statedemo/employer) but it does not seem to have any
effect.
> Is there a way for me to do this without setting the maxscaledemo
> parameter? I would like to view these employer locations from the
> overview but identify less than 5 at a time.
> Thanks!
> Jessica
> Let Crystal Reports handle the reporting - Free Crystal Reports 2008
30-Day
> trial. Simplify your report design, integration and deployment - and
focus on
> what you do best, core application coding. Discover what's new with
> Crystal Reports now. http://p.sf.net/sfu/bobj-july
> Geomoose-users mailing list
> Geomoose-users at lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/geomoose-users
30-Day
focus on
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20090806/6afdb868/attachment.html
More information about the Geomoose-users
