[Geomoose-users] Limit Identify Result
Brent Fraser
bfraser at geoanalytic.com
Thu Aug 6 15:10:41 EDT 2009
Jessica,
I don't think "query_limit" has been implemented in Mapserver yet
(http://trac.osgeo.org/mapserver/ticket/2424). The only option I can think of
is to do some PHP (or other scripting language) programming, similar to GM's
select.php and limit the returned results there.
But you might want to ask the question on the Mapserver-users email list.
Best Regards,
Brent Fraser
Jessica Fendos wrote:
> Hi list:
> I am using GeoMoose 1.6.1. I have several point layers (employers by
> industry) that I would like to display in the mapping interface. Due to
> InfoUSA data restriction, I would like to limit the display of records
> resulting from the "Identify" tool to 5.
> I added the following
> *METADATA
> "query_limit" "5"
> END*
> to this layer in identify.map (under maps_statedemo) and employer.map
> (under maps_statedemo/employer) but it does not seem to have any effect.
> Is there a way for me to do this without setting the maxscaledemo
> parameter? I would like to view these employer locations from the
> overview but identify less than 5 at a time.
> Thanks!
> Jessica
> Let Crystal Reports handle the reporting - Free Crystal Reports 2008 30-Day
> trial. Simplify your report design, integration and deployment - and focus on
> what you do best, core application coding. Discover what's new with
> Crystal Reports now. http://p.sf.net/sfu/bobj-july
> Geomoose-users mailing list
> Geomoose-users at lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/geomoose-users
More information about the Geomoose-users
