[Geomoose-users] Limit Identify Result
Jessica Fendos
Jessica.Fendos at state.mn.us
Mon Aug 10 23:20:43 EDT 2009
Thanks Dan. There is already a ticket for implementing this in MapServer
(Milestone 6.0?). We look forward to it.
Jessica
>>> Dan Little <danlittle at yahoo.com> 08/10/09 9:50 PM >>>
To get this into GM I'll need to modify MapServer, at least if I want it
to work universally.
>From: Jessica Fendos <Jessica.Fendos at state.mn.us>
>To: Brent Fraser <bfraser at geoanalytic.com>; Dan Little
>Cc: geomoose-users at lists.sourceforge.net
>Sent: Thursday, August 6, 2009 3:11:21 PM
>Subject: Re: [Geomoose-users] Limit Identify Result
>Dan:
>Sorry if I put you on a hot spot. I was hoping this feature would be
added to GeoMoose. The mapping interface will not be too demanding
except I have to limit query result. It sounds like I am really pushing
it for this time frame. Would you consider adding this feature in 2.0
(or 2.0.1) when it is convenient to you in the near future (does not
have to be before 8/14)? Thank you!
>Jessica
>>>> Dan Little <danlittle at yahoo.com> 8/6/2009 2:58 PM >>>
>Are you saying you would need this feature added to GeoMOOSE by August
14th? Or are you saying you need assistance setting up GeoMOOSE for the
State Fair booth?
>It might be a possibility for me to write the feature into GM2.0 by the
14th but probably not GM1.6 (as GM2.0 actually has an identify service
using PHP, so there is more control).
>>Sent: Thursday, August 6, 2009 2:52:23 PM
>>Dan:
>>It will be of value to entities dealing with "licensed" data.
Actually, I was going to use GeoMoose to display green career
opportunities at the coming State Fair Green Career booth organized by
the Department of Employment and Economic Development -- showing "green"
educational programs and industries. If it is not too much trouble,
would you consider? However, the deadline is August 14th. If you are
busy at this time, we can always use GeoMoose next time when
appropriate. Thank you either way.
>>Best,
>>Jessica
>>>>> Dan Little <danlittle at yahoo.com> 8/6/2009 2:40 PM >>>
>>This the first request for the feature that I've heard, so no, it's
not implemented. It wouldn't be a difficult add-on to either GM1.6.X or
GM2.0 ... shall I consider the option officially requested?
>>>Sent: Thursday, August 6, 2009 2:33:21 PM
>>>Thanks Dan for the quick response. I know GeoMoose 2.0 is built on
MapServer and OpenLayers. Will 2.0 take care of identify limit at this
time? Appreciate your time!
>>>Jessica
>>>>>> Dan Little <danlittle at yahoo.com> 8/6/2009 2:27 PM >>>
>>>That add-on is something chameleon implemented. For identify
functionality GeoMOOSE 1.6.X uses MapServer directly, so if it's not a
native-MapServer supported function it will not work with GeoMOOSE 1.6.X
>>>>Sent: Thursday, August 6, 2009 2:23:20 PM
>>>>Thanks Brent:
>>>>I was able to limit the identify result using this metadata tag in
Chameleon (another add-on to MapServer) so was hoping I can do the same
in GeoMoose.... Suggestions anyone?
>>>>Jessica
>>>>>>> Brent Fraser <bfraser at geoanalytic.com> 8/6/2009 2:10 PM >>>
>>>>Jessica,
>>>> I don't think "query_limit" has been implemented in Mapserver yet
>>>>(http://trac.osgeo.org/mapserver/ticket/2424). The only option I
can think of
>>>>is to do some PHP (or other scripting language) programming, similar
to GM's
>>>>select.php and limit the returned results there.
>>>> But you might want to ask the question on the Mapserver-users
email list.
>>>>Best Regards,
>>>>Brent Fraser
>>>>Jessica Fendos wrote:
>>>>> Hi list:
>>>>> I am using GeoMoose 1.6.1. I have several point layers (employers
by
>>>>> industry) that I would like to display in the mapping interface.
Due to
>>>>> InfoUSA data restriction, I would like to limit the display of
records
>>>>> resulting from the "Identify" tool to 5.
>>>>> I added the following
>>>>> *METADATA
>>>>> "query_limit" "5"
>>>>> END*
>>>>> to this layer in identify.map (under maps_statedemo) and
employer.map
>>>>> (under maps_statedemo/employer) but it does not seem to have any
effect.
>>>>> Is there a way for me to do this without setting the maxscaledemo
>>>>> parameter? I would like to view these employer locations from the
>>>>> overview but identify less than 5 at a time.
>>>>> Thanks!
>>>>> Jessica
>>>>> Let Crystal Reports handle the reporting - Free Crystal Reports
2008 30-Day
>>>>> trial. Simplify your report design, integration and deployment -
and focus on
>>>>> what you do best, core application coding. Discover what's new
with
>>>>> Crystal Reports now. http://p.sf.net/sfu/bobj-july
>>>>> _______________________________________________
>>>>> Geomoose-users mailing list
>>>>> Geomoose-users at lists.sourceforge.net
>>>>> https://lists.sourceforge.net/lists/listinfo/geomoose-users
>>>>Let Crystal Reports handle the reporting - Free Crystal Reports 2008
30-Day
>>>>trial. Simplify your report design, integration and deployment - and
focus on
>>>>what you do best, core application coding. Discover what's new with
More information about the Geomoose-users
