[Geomoose-users] search on more than one layer - GM 2.0
Dan Little
danlittle at yahoo.com
Wed Aug 19 00:48:52 EDT 2009
Hey Mark,
I looked into this tonight and there is a bit of a problem searching multiple layers using the itemquery.php tool. That is because the field "qitem" needs to be searched against the layer.
>From: Mark Volz <MarkVolz at co.lyon.mn.us>
>To: geomoose-users at lists.sourceforge.net
>Sent: Tuesday, August 11, 2009 9:16:46 AM
>Subject: [Geomoose-users] search on more than one layer - GM 2.0
>Hello,
>I would like to set up GM 2.0 to search for more than one
>layer, and I am having difficulty setting it up. Is there any
>documentation on how to get multiple searches working?
>In detail:
>I was trying to add another search for a second layer.
>I looked at the code for itemquery.php and noticed that that the input value layers
>gets exploded which to me implies that we can use the search service for more
>than one layer. - $layersToSearch = explode(':', $qlayers);
>Therefore, I modified the search service to include ditches
>in the mapbook.xml file <input type="hidden"
>name="layer" value="parcels/all:Ditches/all"/>
>However when I did that I received errors.
>Since that did not work I reverted to copied search_parcels to
>search_ditches. Next, I modified the user_tools.css file so to include
>search ditches as well. After testing a search the only message I received
>is that no results were returned for your query.
>Thanks
>Mark Volz
>GIS Specialist
>Lyon County,
> MN
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20090818/8df394b9/attachment.html
More information about the Geomoose-users
