[Geomoose-users] Scalebar in GM2
Len Kne
lkne at houstoneng.com
Wed Aug 19 16:39:29 EDT 2009
Not sure if this would help, but it is also possible to get the scale line drawn through OpenLayers. I see the latest version on the SVN trunk includes the code to do this.
Len
-----Original Message-----
Sent: Wednesday, August 19, 2009 12:33 PM
To: Dan Little
Cc: GeoMoose Mailing list
Subject: Re: [Geomoose-users] Scalebar in GM2
The learning by doing approach ;-) thanks.
I put MAP .. END around the whole thing and it works when being called
directly via URL - but still no scalebar in GM. The scalebar mapfile
referenced in the mapbook now looks like:
MAP
TRANSPARENT true
OUTPUTFORMAT
NAME 'agg/png'
DRIVER 'agg/png'
MIMETYPE 'image/png'
IMAGEMODE 'rgba'
EXTENSION 'png'
FORMATOPTION 'TRANSPARENT=TRUE'
END # OUTPUTFORMAT
IMAGETYPE 'agg/png'
IMAGECOLOR 255 255 255
SCALEBAR
INTERVALS 5
UNITS kilometers
STATUS embed
POSTLABELCACHE true
POSITION ul
OUTLINECOLOR 0 0 0
BACKGROUNDCOLOR 255 255 255
STYLE 0
LABEL
COLOR 0 0 0
OUTLINECOLOR 255 255 255
SIZE medium
END #LABEL
END # SCALEBAR
END # MAP
And second, how to make the scalebar entry disappear from the layer catalog?
Thanks,
Nils
Dan Little schrieb:
> In Firefox, go to "Tools" -> "Page Info" and click on the "Media" tab (or the German equivalents).
> Scroll down to where you see the URL for the scale bar request. Copy the URL and open it up in a new tab/window. It should show a MapServer error. Address the mapserver error and everything should work properly. :)
> ----- Original Message ----
>> From: CoFIS Web <coffee at uni-bonn.de>
>> To: GeoMoose Mailing list <geomoose-users at lists.sourceforge.net>
>> Sent: Wednesday, August 19, 2009 11:15:23 AM
>> Subject: [Geomoose-users] Scalebar in GM2
>> Dear all,
>> which would be the place to enable a global scalebar in GM2?
>> I tried including a mapfile in my mapbook with
>> ./defaults/scalebar.map
>> and in the catalog
>> But that does not seem to work (pink background in GM).
>> The following scalebar.map works if I include it into a mapfile and call
>> that mapfile directly via URL:
>> SCALEBAR
>> INTERVALS 4
>> STATUS embed
>> STYLE 0
>> OUTLINECOLOR 0 0 0
>> POSITION ll
>> UNITS kilometers
>> LABEL
>> COLOR 0 0 0
>> SIZE medium
>> END #LABEL
>> END # SCALEBAR
>> Any suggestions? Thanks,
>> Nils
>> Center for Development Research
>> Department of Ecology and Resource Management
>> Walter-Flex-Strasse 3
>> 53113 Bonn (Germany)
>> Tel.: +49 (0) 228 - 73-1793
>> FAX: +49 (0) 228 - 73-1889
>> E-Mail: coffee at uni-bonn.de
>> Web: http://www.cofis.info/atlas
>> http://www.coffee.uni-bonn.de
>> Let Crystal Reports handle the reporting - Free Crystal Reports 2008 30-Day
>> trial. Simplify your report design, integration and deployment - and focus on
>> what you do best, core application coding. Discover what's new with
>> Crystal Reports now. http://p.sf.net/sfu/bobj-july
>> Geomoose-users mailing list
>> Geomoose-users at lists.sourceforge.net
>> https://lists.sourceforge.net/lists/listinfo/geomoose-users
More information about the Geomoose-users
