[Geomoose-users] Scalebar in GM2
CoFIS Web
coffee at uni-bonn.de
Thu Aug 20 08:05:32 EDT 2009
Len,
Thanks for the notice. I use the OL code and it works fine.
A question to the list:
Is it possible to have either the top or bottom scale line enabled
exclusively? I would only need to show kilometers, since I am working
with small scale maps.
Thanks,
Nils
Len Kne schrieb:
> Not sure if this would help, but it is also possible to get the scale line drawn through OpenLayers. I see the latest version on the SVN trunk includes the code to do this.
> Len
> -----Original Message-----
> From: CoFIS Web [mailto:coffee at uni-bonn.de]
> Sent: Wednesday, August 19, 2009 12:33 PM
> To: Dan Little
> Cc: GeoMoose Mailing list
> Subject: Re: [Geomoose-users] Scalebar in GM2
> The learning by doing approach ;-) thanks.
> I put MAP .. END around the whole thing and it works when being called
> directly via URL - but still no scalebar in GM. The scalebar mapfile
> referenced in the mapbook now looks like:
> MAP
> TRANSPARENT true
> OUTPUTFORMAT
> NAME 'agg/png'
> DRIVER 'agg/png'
> MIMETYPE 'image/png'
> IMAGEMODE 'rgba'
> EXTENSION 'png'
> FORMATOPTION 'TRANSPARENT=TRUE'
> END # OUTPUTFORMAT
> IMAGETYPE 'agg/png'
> IMAGECOLOR 255 255 255
> SCALEBAR
> INTERVALS 5
> UNITS kilometers
> STATUS embed
> POSTLABELCACHE true
> POSITION ul
> OUTLINECOLOR 0 0 0
> BACKGROUNDCOLOR 255 255 255
> STYLE 0
> LABEL
> COLOR 0 0 0
> OUTLINECOLOR 255 255 255
> SIZE medium
> END #LABEL
> END # SCALEBAR
> END # MAP
> And second, how to make the scalebar entry disappear from the layer catalog?
> Thanks,
> Nils
> Dan Little schrieb:
>> In Firefox, go to "Tools" -> "Page Info" and click on the "Media" tab (or the German equivalents).
>> Scroll down to where you see the URL for the scale bar request. Copy the URL and open it up in a new tab/window. It should show a MapServer error. Address the mapserver error and everything should work properly. :)
>> ----- Original Message ----
>>> From: CoFIS Web <coffee at uni-bonn.de>
>>> To: GeoMoose Mailing list <geomoose-users at lists.sourceforge.net>
>>> Sent: Wednesday, August 19, 2009 11:15:23 AM
>>> Subject: [Geomoose-users] Scalebar in GM2
>>> Dear all,
>>> which would be the place to enable a global scalebar in GM2?
>>> I tried including a mapfile in my mapbook with
>>> ./defaults/scalebar.map
>>> and in the catalog
>>> But that does not seem to work (pink background in GM).
>>> The following scalebar.map works if I include it into a mapfile and call
>>> that mapfile directly via URL:
>>> SCALEBAR
>>> INTERVALS 4
>>> STATUS embed
>>> STYLE 0
>>> OUTLINECOLOR 0 0 0
>>> POSITION ll
>>> UNITS kilometers
>>> LABEL
>>> COLOR 0 0 0
>>> SIZE medium
>>> END #LABEL
>>> END # SCALEBAR
>>> Any suggestions? Thanks,
>>> Nils
>>> Center for Development Research
>>> Department of Ecology and Resource Management
>>> Walter-Flex-Strasse 3
>>> 53113 Bonn (Germany)
>>> Tel.: +49 (0) 228 - 73-1793
>>> FAX: +49 (0) 228 - 73-1889
>>> E-Mail: coffee at uni-bonn.de
>>> Web: http://www.cofis.info/atlas
>>> http://www.coffee.uni-bonn.de
>>> Let Crystal Reports handle the reporting - Free Crystal Reports 2008 30-Day
>>> trial. Simplify your report design, integration and deployment - and focus on
>>> what you do best, core application coding. Discover what's new with
>>> Crystal Reports now. http://p.sf.net/sfu/bobj-july
>>> Geomoose-users mailing list
>>> Geomoose-users at lists.sourceforge.net
>>> https://lists.sourceforge.net/lists/listinfo/geomoose-users
More information about the Geomoose-users
