[Geomoose-users] Scalebar in GM2
Dan Little
danlittle at yahoo.com
Thu Aug 20 13:51:18 EDT 2009
I've logged the lack of graphic scalebar as a ticket. Ticket #9, in fact. I've tagged it for the 2.2 release becauseI I'm hoping to get the 2.0.1 release rounded up yet this week (yikes it's Thursday). There is some testing being finished and we've updated the package build system.
----- Original Message ----
> From: CoFIS Web <coffee at uni-bonn.de>
> To: Len Kne <lkne at houstoneng.com>
> Cc: GeoMoose Mailing list <geomoose-users at lists.sourceforge.net>
> Sent: Thursday, August 20, 2009 7:05:32 AM
> Subject: Re: [Geomoose-users] Scalebar in GM2
> Len,
> Thanks for the notice. I use the OL code and it works fine.
> A question to the list:
> Is it possible to have either the top or bottom scale line enabled
> exclusively? I would only need to show kilometers, since I am working
> with small scale maps.
> Thanks,
> Nils
> Len Kne schrieb:
> > Not sure if this would help, but it is also possible to get the scale line
> drawn through OpenLayers. I see the latest version on the SVN trunk includes
> the code to do this.
> > Len
> > -----Original Message-----
> > From: CoFIS Web [mailto:coffee at uni-bonn.de]
> > Sent: Wednesday, August 19, 2009 12:33 PM
> > To: Dan Little
> > The learning by doing approach ;-) thanks.
> > I put MAP .. END around the whole thing and it works when being called
> > directly via URL - but still no scalebar in GM. The scalebar mapfile
> > referenced in the mapbook now looks like:
> > MAP
> > TRANSPARENT true
> > OUTPUTFORMAT
> > NAME 'agg/png'
> > DRIVER 'agg/png'
> > MIMETYPE 'image/png'
> > IMAGEMODE 'rgba'
> > EXTENSION 'png'
> > FORMATOPTION 'TRANSPARENT=TRUE'
> > END # OUTPUTFORMAT
> > IMAGETYPE 'agg/png'
> > IMAGECOLOR 255 255 255
> > SCALEBAR
> > INTERVALS 5
> > UNITS kilometers
> > STATUS embed
> > POSTLABELCACHE true
> > POSITION ul
> > OUTLINECOLOR 0 0 0
> > BACKGROUNDCOLOR 255 255 255
> > STYLE 0
> > LABEL
> > COLOR 0 0 0
> > OUTLINECOLOR 255 255 255
> > SIZE medium
> > END #LABEL
> > END # SCALEBAR
> > END # MAP
> > And second, how to make the scalebar entry disappear from the layer catalog?
> > Thanks,
> > Nils
> > Dan Little schrieb:
> >> In Firefox, go to "Tools" -> "Page Info" and click on the "Media" tab (or the
> German equivalents).
> >> Scroll down to where you see the URL for the scale bar request. Copy the URL
> and open it up in a new tab/window. It should show a MapServer error. Address
> the mapserver error and everything should work properly. :)
> >>> From: CoFIS Web
> >>> To: GeoMoose Mailing list
> >>> Sent: Wednesday, August 19, 2009 11:15:23 AM
> >>> Subject: [Geomoose-users] Scalebar in GM2
> >>> Dear all,
> >>> which would be the place to enable a global scalebar in GM2?
> >>> I tried including a mapfile in my mapbook with
> >>> ./defaults/scalebar.map
> >>> and in the catalog
> >>> But that does not seem to work (pink background in GM).
> >>> The following scalebar.map works if I include it into a mapfile and call
> >>> that mapfile directly via URL:
> >>> SCALEBAR
> >>> INTERVALS 4
> >>> STATUS embed
> >>> STYLE 0
> >>> OUTLINECOLOR 0 0 0
> >>> POSITION ll
> >>> UNITS kilometers
> >>> LABEL
> >>> COLOR 0 0 0
> >>> SIZE medium
> >>> END #LABEL
> >>> END # SCALEBAR
> >>> Any suggestions? Thanks,
> >>> Nils
> >>> Center for Development Research
> >>> Department of Ecology and Resource Management
> >>> Walter-Flex-Strasse 3
> >>> 53113 Bonn (Germany)
> >>> Tel.: +49 (0) 228 - 73-1793
> >>> FAX: +49 (0) 228 - 73-1889
> >>> E-Mail: coffee at uni-bonn.de
> >>> Web: http://www.cofis.info/atlas
> >>> http://www.coffee.uni-bonn.de
> >>> Let Crystal Reports handle the reporting - Free Crystal Reports 2008 30-Day
> >>> trial. Simplify your report design, integration and deployment - and focus
> on
> >>> what you do best, core application coding. Discover what's new with
> >>> Crystal Reports now. http://p.sf.net/sfu/bobj-july
> >>> _______________________________________________
> >>> Geomoose-users mailing list
> >>> Geomoose-users at lists.sourceforge.net
> >>> https://lists.sourceforge.net/lists/listinfo/geomoose-users
> trial. Simplify your report design, integration and deployment - and focus on
More information about the Geomoose-users
