[Geomoose-users] Scalebar in GM2
CoFIS Web
coffee at uni-bonn.de
Tue Aug 25 10:44:46 EDT 2009
Great, thanks.
Nils
Len Kne schrieb:
> I think adding this to the mapbook will work:
> <param name="scale_line.top_units"></param>
> More info on OL scalelines
> http://n2.nabble.com/ScaleLine-km-only-td1828310.html#a16717688
> Len
> -----Original Message-----
> From: CoFIS Web [mailto:coffee at uni-bonn.de]
> Sent: Thursday, August 20, 2009 7:06 AM
> To: Len Kne
> Cc: GeoMoose Mailing list
> Subject: Re: [Geomoose-users] Scalebar in GM2
> Len,
> Thanks for the notice. I use the OL code and it works fine.
> A question to the list:
> Is it possible to have either the top or bottom scale line enabled
> exclusively? I would only need to show kilometers, since I am working
> with small scale maps.
> Thanks,
> Nils
> Len Kne schrieb:
>> Not sure if this would help, but it is also possible to get the scale line drawn through OpenLayers. I see the latest version on the SVN trunk includes the code to do this.
>> Len
>> Sent: Wednesday, August 19, 2009 12:33 PM
>> To: Dan Little
>> The learning by doing approach ;-) thanks.
>> I put MAP .. END around the whole thing and it works when being called
>> directly via URL - but still no scalebar in GM. The scalebar mapfile
>> referenced in the mapbook now looks like:
>> MAP
>> TRANSPARENT true
>> OUTPUTFORMAT
>> NAME 'agg/png'
>> DRIVER 'agg/png'
>> MIMETYPE 'image/png'
>> IMAGEMODE 'rgba'
>> EXTENSION 'png'
>> FORMATOPTION 'TRANSPARENT=TRUE'
>> END # OUTPUTFORMAT
>> IMAGETYPE 'agg/png'
>> IMAGECOLOR 255 255 255
>> SCALEBAR
>> INTERVALS 5
>> UNITS kilometers
>> STATUS embed
>> POSTLABELCACHE true
>> POSITION ul
>> OUTLINECOLOR 0 0 0
>> BACKGROUNDCOLOR 255 255 255
>> STYLE 0
>> LABEL
>> COLOR 0 0 0
>> OUTLINECOLOR 255 255 255
>> SIZE medium
>> END #LABEL
>> END # SCALEBAR
>> END # MAP
>> And second, how to make the scalebar entry disappear from the layer catalog?
>> Thanks,
>> Nils
>> Dan Little schrieb:
>>> In Firefox, go to "Tools" -> "Page Info" and click on the "Media" tab (or the German equivalents).
>>> Scroll down to where you see the URL for the scale bar request. Copy the URL and open it up in a new tab/window. It should show a MapServer error. Address the mapserver error and everything should work properly. :)
>>> ----- Original Message ----
>>>> From: CoFIS Web <coffee at uni-bonn.de>
>>>> To: GeoMoose Mailing list <geomoose-users at lists.sourceforge.net>
>>>> Sent: Wednesday, August 19, 2009 11:15:23 AM
>>>> Subject: [Geomoose-users] Scalebar in GM2
>>>> Dear all,
>>>> which would be the place to enable a global scalebar in GM2?
>>>> I tried including a mapfile in my mapbook with
>>>> ./defaults/scalebar.map
>>>> and in the catalog
>>>> But that does not seem to work (pink background in GM).
>>>> The following scalebar.map works if I include it into a mapfile and call
>>>> that mapfile directly via URL:
>>>> SCALEBAR
>>>> INTERVALS 4
>>>> STATUS embed
>>>> STYLE 0
>>>> OUTLINECOLOR 0 0 0
>>>> POSITION ll
>>>> UNITS kilometers
>>>> LABEL
>>>> COLOR 0 0 0
>>>> SIZE medium
>>>> END #LABEL
>>>> END # SCALEBAR
>>>> Any suggestions? Thanks,
>>>> Nils
>>>> Center for Development Research
>>>> Department of Ecology and Resource Management
>>>> Walter-Flex-Strasse 3
>>>> 53113 Bonn (Germany)
>>>> Tel.: +49 (0) 228 - 73-1793
>>>> FAX: +49 (0) 228 - 73-1889
>>>> E-Mail: coffee at uni-bonn.de
>>>> Web: http://www.cofis.info/atlas
>>>> http://www.coffee.uni-bonn.de
>>>> Let Crystal Reports handle the reporting - Free Crystal Reports 2008 30-Day
>>>> trial. Simplify your report design, integration and deployment - and focus on
>>>> what you do best, core application coding. Discover what's new with
>>>> Crystal Reports now. http://p.sf.net/sfu/bobj-july
>>>> _______________________________________________
>>>> Geomoose-users mailing list
>>>> Geomoose-users at lists.sourceforge.net
>>>> https://lists.sourceforge.net/lists/listinfo/geomoose-users
More information about the Geomoose-users
