[Geomoose-users] Reference map: Size and scale settings
    Len Kne
    lkne at houstoneng.com
    Wed Aug 26 09:23:22 EDT 2009
Nils
Most likely you will need to put the script in compiled.js, but you may want to check your geomoose.html file to see what JavaScript files are being referenced.  You should not need to change other files. Try this:
	if(CONFIGURATION.reference_map.enabled) {
		var referenceMapOptions = {
		ReferenceMap = new OpenLayers.Control.OverviewMap(referenceMapOptions);
		Map.addControl(ReferenceMap);
See http://trac.openlayers.org/wiki/Control/OverviewMap for more options.
Len
-----Original Message-----
Sent: Tuesday, August 25, 2009 10:06 AM
To: Len Kne
Cc: GeoMoose Mailing list
Subject: Re: [Geomoose-users] Reference map: Size and scale settings
Len,
I am not that familiar with JavaScript (but willing to learn). Three
questions I got so far:
- Into which file would I put that - into htdocs/compiled.js?
- How would I have to add the option (see below)?
- are there any other files I would have to change?
In htdocs/compiled.js would it be something like this (tried with no
success)?
		ReferenceMap = new OpenLayers.Control.OverviewMap();
Thanks,
Nils
Len Kne schrieb:
> The following javascript works to change the size of the reference map.
> And then look for where ReferenceMap is created and have it use the options you defined.
> I think you can define the other options you mentioned as well, check the OpenLayers documentation.
> Len
> From: CoFIS Web [mailto:coffee at uni-bonn.de]
> Sent: Wednesday, August 19, 2009 11:29 AM
> To: GeoMoose Mailing list
> Subject: [Geomoose-users] Reference map: Size and scale settings
> Dear all,
> which files do I have to work with for modifying the reference map's
> - size (x,y)
> - outline color and line with
> - scale in relation to GM's main map window.
> In GM 1.6 it was the configuration.js, but I had no luck in crawling
> through htdocs/compiled.js and htdocs/geomoose/*.
> Actually, it would be nice if I was able to define the parameters in the
> mapbook.
> Thanks,
> Nils
Center for Development Research
Department of Ecology and Resource Management
Walter-Flex-Strasse 3
53113 Bonn (Germany)
Tel.:   +49 (0) 228 - 73-1793
FAX:    +49 (0) 228 - 73-1889
E-Mail: coffee at uni-bonn.de
Web:    http://www.cofis.info/atlas
         http://www.coffee.uni-bonn.de
More information about the Geomoose-users
