[Geomoose-users] Reference map: Size and scale settings
CoFIS Web coffee at uni-bonn.de
Tue Aug 25 11:05:30 EDT 2009
Len,
I am not that familiar with JavaScript (but willing to learn). Three
questions I got so far:
- Into which file would I put that - into htdocs/compiled.js?
- How would I have to add the option (see below)?
- are there any other files I would have to change?
In htdocs/compiled.js would it be something like this (tried with no
success)?
	if(CONFIGURATION.reference_map.enabled) {
		ReferenceMap = new OpenLayers.Control.OverviewMap();
		Map.addControl(ReferenceMap);
	var referenceMapOptions = {
Thanks,
Nils
Len Kne schrieb:
> The following javascript works to change the size of the reference map.
> And then look for where ReferenceMap is created and have it use the options you defined.
> 	ReferenceMap = new OpenLayers.Control.OverviewMap(referenceMapOptions);
> I think you can define the other options you mentioned as well, check the OpenLayers documentation.
> Len
> -----Original Message-----
> From: CoFIS Web [mailto:coffee at uni-bonn.de]
> Sent: Wednesday, August 19, 2009 11:29 AM
> To: GeoMoose Mailing list
> Subject: [Geomoose-users] Reference map: Size and scale settings
> Dear all,
> which files do I have to work with for modifying the reference map's
> - size (x,y)
> - outline color and line with
> - scale in relation to GM's main map window.
> In GM 1.6 it was the configuration.js, but I had no luck in crawling
> through htdocs/compiled.js and htdocs/geomoose/*.
> Actually, it would be nice if I was able to define the parameters in the
> mapbook.
> Thanks,
> Nils
Center for Development Research
Department of Ecology and Resource Management
Walter-Flex-Strasse 3
53113 Bonn (Germany)
Tel.:   +49 (0) 228 - 73-1793
FAX:    +49 (0) 228 - 73-1889
E-Mail: coffee at uni-bonn.de
Web:    http://www.cofis.info/atlas
         http://www.coffee.uni-bonn.de
More information about the Geomoose-users mailing list
