[Geomoose-users] Reference map: Size and scale settings
Len Kne
lkne at houstoneng.com
Wed Aug 19 16:20:03 EDT 2009
The following javascript works to change the size of the reference map.
var referenceMapOptions = {
And then look for where ReferenceMap is created and have it use the options you defined.
ReferenceMap = new OpenLayers.Control.OverviewMap(referenceMapOptions);
I think you can define the other options you mentioned as well, check the OpenLayers documentation.
Len
-----Original Message-----
Sent: Wednesday, August 19, 2009 11:29 AM
To: GeoMoose Mailing list
Subject: [Geomoose-users] Reference map: Size and scale settings
Dear all,
which files do I have to work with for modifying the reference map's
- size (x,y)
- outline color and line with
- scale in relation to GM's main map window.
In GM 1.6 it was the configuration.js, but I had no luck in crawling
through htdocs/compiled.js and htdocs/geomoose/*.
Actually, it would be nice if I was able to define the parameters in the
mapbook.
Thanks,
Nils
Center for Development Research
Department of Ecology and Resource Management
Walter-Flex-Strasse 3
53113 Bonn (Germany)
Tel.: +49 (0) 228 - 73-1793
FAX: +49 (0) 228 - 73-1889
E-Mail: coffee at uni-bonn.de
Web: http://www.cofis.info/atlas
http://www.coffee.uni-bonn.de
Let Crystal Reports handle the reporting - Free Crystal Reports 2008 30-Day
trial. Simplify your report design, integration and deployment - and focus on
what you do best, core application coding. Discover what's new with
Crystal Reports now. http://p.sf.net/sfu/bobj-july
Geomoose-users mailing list
Geomoose-users at lists.sourceforge.net
https://lists.sourceforge.net/lists/listinfo/geomoose-users
More information about the Geomoose-users
