[Geomoose-users] GM2: Where to put customized JS-code to
survive revision upgrades
Dan Little
danlittle at yahoo.com
Mon Aug 31 10:46:21 EDT 2009
Well, I'd be interested in the patches to see what is applicable to roll into trunk. :-)
Right now, there is not a lot of architecture for doing this. Really, compiled.js shouldn't get modified. The actual source script in htdocs/geomoose should be edited and compiled.js should be rebuilt using compileGeomoose.py in the tools directory.
I was in the process of writing a development guide on this and then realized that I really need to code an user-extensions architecture. :-|
----- Original Message ----
> From: CoFIS Web <coffee at uni-bonn.de>
> To: GeoMoose Mailing list <geomoose-users at lists.sourceforge.net>; "geomoose-developers at lists.sourceforge.net" <geomoose-developers at lists.sourceforge.net>
> Sent: Monday, August 31, 2009 9:35:26 AM
> Subject: [Geomoose-users] GM2: Where to put customized JS-code to survive revision upgrades
> Dear all,
> is there an easy way to maintain custom changes to JavaScript code,
> across revision upgrades?
> I did change a few lines in htdocs/compiled.js to modify my reference map.
> - How would I put that into a seperate script so that the changes
> override the defaults in htdocs/compiled.js?
> - Would I have to modify any files exept for geomoose.html to include
> the new js-file?
> Thank you,
> Nils
> Center for Development Research
> Department of Ecology and Resource Management
> Walter-Flex-Strasse 3
> 53113 Bonn (Germany)
> Tel.: +49 (0) 228 - 73-1793
> FAX: +49 (0) 228 - 73-1889
> E-Mail: coffee at uni-bonn.de
> Web: http://www.cofis.info/atlas
> http://www.coffee.uni-bonn.de
> Let Crystal Reports handle the reporting - Free Crystal Reports 2008 30-Day
> trial. Simplify your report design, integration and deployment - and focus on
> what you do best, core application coding. Discover what's new with
> Crystal Reports now. http://p.sf.net/sfu/bobj-july
> Geomoose-users mailing list
> Geomoose-users at lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/geomoose-users
More information about the Geomoose-users
