[Geomoose-users] getting started with gm2
Dan Little danlittle at yahoo.com
Wed Dec 16 14:00:45 EST 2009
Moving those files to the htdocs directory is an extremely bad idea for a few reasons:
1) it makes your data downlaodable.
2) it makes your configuration (including critical system information) publically exposed.
It's like running naked in the snow, you can do it, but it's a really bad idea.
>From: Jim Hagedorn <jhagedorn at bannerassociates.com>
>To: Dan Little <danlittle at yahoo.com>
>Cc: GeoMOOSE Users List <geomoose-users at lists.sourceforge.net>
>Sent: Wed, December 16, 2009 12:54:47 PM
>Subject: RE: [Geomoose-users] getting started with gm2
>Dan
>Where is the getmapbook.php
>called?  In the onLoad=”main();” which calls the
>main.js?  since I have moved the conf and maps directories to same level
>as the as the html, I’m trying to track down the files that have the
>calls in them to correct the directory calls to get to the getmapbook.php and
>eventually the settings.ini.  hope that made sense.
>Thanks
>jim
>From:Dan Little
>[mailto:danlittle at yahoo.com]
>Sent: Wednesday, December 16, 2009 11:34 AM
>To: Jim Hagedorn
>Subject: Re: [Geomoose-users] getting started with gm2
>It's never called from the HTML.
>>Geomoose.html calls getmapbook.php... getmapbook.php reads the settings.ini to
>determine which mapbook to return... getmapbook.php then returns the mapbook
>where the rest of the settings are stored.
>>From:Jim Hagedorn
>>To: Dan Little <danlittle at yahoo.com>;
>>"geomoose-users at lists.sourceforge.net"
>>Sent: Wed, December 16, 2009 11:31:32 AM
>>Dan
>>So at what point in the
>>geomoose.html is the setting.ini called?  Just trying to get in my mind
>>the sequence of calls and what calls what.
>>Thanks
>>jim
>>From:Dan Little
>>Sent: Wednesday, December 16, 2009 10:48 AM
>>To: Jim Hagedorn; geomoose-users at lists.sourceforge.net
>>Hey
>>Jim,
>>>>Sorry I didn't back to you when you wrote the earlier email.  I've been
>>meaning to do so.
>>>>Here's how the various files work:
>>>>* settings.ini - This tells all the services where stuff is, which mapbook to
>>use, etc.
>>>>* config.php - This isn't really used any more like it was in 1.X, most
>>everything is dedicately stored in settings.ini
>>>>* mapbook.xml is actually served by getmapbook.php based on the setting in
>>settings.ini.  This has been established as the ground work for future
>>enhancements to the application.  Specifically, the ability to create user
>>names/accounts, and have different mapbooks served based on the account
>>pliverages.
>>>From:Jim Hagedorn
>>>To: "geomoose-users at lists.sourceforge.net"
>>>Sent: Wed, December 16, 2009 10:43:57 AM
>>>Subject: [Geomoose-users] getting started with gm2
>>>Can someone tell me the order of files that are called when
>>>the html is called.  The html file should call a file that calls the files
>>>that do the configurations and set up.  So from geomoose.html, what file is
>>>called in that html to get to settings.ini and config.php and
>>>mapbook.xml?
>>>Just trying to get started in gm2.
>>>thanks
>>>Jim
>>>Hagedorn
>>>GIS
>>>Specialist
>>>Banner Associates, Inc.
>>>409 22nd Avenue South · PO
>>>Box 298 · Brookings, South Dakota 57006
>>>(605) 692-6342 ·  Fax(605) 692-5714
>>>www.bannerassociates.com
Skipped content of type multipart/related
More information about the Geomoose-users mailing list
