[Geomoose-users] getting started with gm2
Mark Volz
MarkVolz at co.lyon.mn.us
Wed Dec 16 15:17:38 EST 2009
Jim,
The files referenced in order are:
Geomoose.html>Getmapbook.php>Config.php>Settings.ini>Mapbook.xml.
If you open up each file you should be able to find the reference to the next
file. However, when I looked at this before I decided to go a different
route. Instead of placing several projects in a single folder you might want
to think about creating one folder for each project. The configuration in
GM2 makes this easy.
IE:
apps\LyonGeoomoose2
apps\PipestoneGeomoose2
apps\DemoGeomoose2
You will notice there
Mark Volz
GIS Specialist
Lyon County, MN
507-532-8218
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20091216/4ebf476c/attachment.html
More information about the Geomoose-users
