[Geomoose-users] Layers still not populating
Dan Little
danlittle at yahoo.com
Fri Jun 26 10:08:46 EDT 2009
Do you happen to have access to firebug and/or Firefox?
----- Original Message ----
> From: "awhitley at charter.net" <awhitley at charter.net>
> To: geomoose-users at lists.sourceforge.net
> Sent: Friday, June 26, 2009 9:03:41 AM
> Subject: [Geomoose-users] Layers still not populating
> Still looking for some insight; I am certain the coordinates on the shapefile
> are in
> NA83 UTM Zone 15 N - epsg 26915.
> I even brought the data in Quantum GIS and produced a mapfile from the Mapserver
> Export plugin just to see what extent it was showing my data in.
> My test data (ga_firestations2.shp) is residing in the countydata folder along
> with the mapfile.
> I verified the configuration.js (countyconfiguration.js) and the extent is set
> to the same as mapfile.
> Mapfile:
> MAP
> NAME 'firestations'
> SIZE 800 650
> STATUS ON
> EXTENT 1311606.064490 3765485.899332 1475727.003496 3868927.480976
> PROJECTION "init=epsg:26915"
> UNITS METERS
> FONTSET '../fonts/fontset.list'
> SYMBOLSET '../symbols/symbol.sym'
> TRANSPARENT TRUE
> IMAGETYPE PNG
> QUERYMAP
> STATUS ON
> STYLE SELECTED
> END
> WEB
> QUERYFORMAT "text/xml"
> INCLUDE "../temp_directory.map"
> END
> LEGEND
> STATUS ON
> END
> LAYER
> NAME 'Firestations'
> DATA './ga_firestations2.shp'
> STATUS DEFAULT
> TYPE POINT
> STATUS DEFAULT
> LABELITEM 'NAME'
> LABELMAXSCALE 20000
> CLASS
> NAME 'Firestations'
> COLOR 255 0 0
> SYMBOL "square"
> SIZE 12
> END
> HEADER 'imagemap_header.xml'
> TEMPLATE 'imagemap_record.xml'
> FOOTER 'imagemap_footer.xml'
> END
> END ## end Map
> Geomoose-users mailing list
> Geomoose-users at lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/geomoose-users
More information about the Geomoose-users
