[Geomoose-users] [Geomoose-developers] Test for layer active
Leonidas Liakos
leonidas_liakos at yahoo.gr
Mon May 11 17:31:28 EDT 2009
Jay, did you find any answer in your question? I also have the same
problem. I need to check if a layer is active.I do it with php/mapscript
but it returns true for all layers (active and inactive layers).So,how
did you handle that? Thank you, Leonidas
Jay Kapalczynski wrote:
> Any thoughts on how to test to see if a layer is active and If so do
> something.
> I want this bit of code to run the entire time the application is
> open....just not sure
> where to write the code in order to achieve this.
> Thanks...
More information about the Geomoose-users
