[Geomoose-users] Geomoose 2 and custom footer data readouts
    Dan Little
    danlittle at yahoo.com
    Tue Nov  3 13:39:28 EST 2009
So, are you trying to show the current elevation under the mouse, in the footer?
On Nov 2, 2009, at 11:08, Johan Forsman <Johan.Forsman at LA.GOV> wrote:
Hello All:
I have an idea to improve our mapserver product, and I come to you asking for help formulating an approach to realizing it.
What I want to attempt is a seamless, continuous readout of elevation data in the Geomoose footer, next to the coordinate-display and scale-jumper features.
I have access to elevation data in the form of USGS DEM rasters, either from 1:24000 quads or from a much denser (and far larger) LIDAR dataset. The quad DEM dataset consists of just under 1000 quads, in what appears to be 16-bit signed integer format, each file with a unique name equal to the USGS quad code. Files appear to be 1-2 megs in size on disk.
The LIDAR dataset appears to use a 32-bit float format, there are over 3500 individual files with unique names that do not correspond directly to the USGS quarter-quad code (but I can possibly generate a lookup table for the translation). Alternatively the LIDAR data is available as CSV format. Files are quite large, 10-12 megs for the rasters and 150 megs for the CSVs. Each.
I am not (yet) interested in displaying the data as an image, only returning the point values at any given location in the footer, and also in the results header when a user clicks on a spot with the identify tool.
How should I (can I? do I need to?) approach crafting a mapserver file that points to 3500+ individual rasters?
Where is the integration point with the footer in Geomoose2? Does the function currently exists to return the type of data I want to display?
Am I thinking all wrong about this? This is very likely.
Should I just forget about the whole thing? Can it even be done?
Please opine at will on this subject.
Thanks!
/Johan.
Johan Forsman
Geologist
Safe Drinking Water Program
Louisiana Department of Health and Hospitals
Office of Public Health
Telephone: 225.342.7309
Telefax: 225.342.7303
Come build with us! The BlackBerry(R) Developer Conference in SF, CA
is the only developer event you need to attend this year. Jumpstart your
developing skills, take BlackBerry mobile applications to market and stay
ahead of the curve. Join us from November 9 - 12, 2009. Register now!
http://p.sf.net/sfu/devconference
Geomoose-users mailing list
Geomoose-users at lists.sourceforge.net
https://lists.sourceforge.net/lists/listinfo/geomoose-users
More information about the Geomoose-users
