[Geomoose-users] GM2.0.1, search function and layer activation
FRANZ OKYERE
franzzoa at hotmail.com
Thu Nov 19 10:10:03 EST 2009
Johann, have a look at the part of itemquery.php where the url is printed. Simply modify which layer is set against turnlayeron See if this helps. FRANZ OKYERE. GIS Specialist.
> From: Johan.Forsman at LA.GOV
> To: geomoose-users at lists.sourceforge.net
> Date: Thu, 19 Nov 2009 08:24:00 -0600
> Subject: [Geomoose-users] GM2.0.1, search function and layer activation
> Hello All:
> GM2.0.1, patched from base MS4W package.
> Using the Search function I can successfully find data from three separate datasets (layers are in the same mapfile). When the search succeeds, all three layers are turned on and the features are highlighted, presumably as designed. What I am so far unable to determine is how to turn those layers off again. They are not checked in the Catalog. If I manually check one of the applicable layers, all three found layers turn off and the manually checked layers turns on. When I turn off the manually checked layer, the found layers turn back on.
> Is there a way to connect the layer activity in the catalog to that of the itemquery.php function?
> Thanks!
> Johan Forsman
> Geologist
> Safe Drinking Water Program
> Louisiana Department of Health and Hospitals
> Office of Public Health
> Telephone: 225.342.7309
> Telefax: 225.342.7303
> Let Crystal Reports handle the reporting - Free Crystal Reports 2008 30-Day
> trial. Simplify your report design, integration and deployment - and focus on
> what you do best, core application coding. Discover what's new with
> Crystal Reports now. http://p.sf.net/sfu/bobj-july
> Geomoose-users mailing list
> Geomoose-users at lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/geomoose-users
_________________________________________________________________
Add your Gmail and Yahoo! Mail email accounts into Hotmail - it's easy
http://clk.atdmt.com/UKM/go/186394592/direct/01/
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20091119/a1e233b4/attachment.html
More information about the Geomoose-users
