[Geomoose-users] select mapfile
t faustino
geomatrix3d at gmail.com
Thu Nov 19 15:57:57 EST 2009
Having an issue I ran into on a previous install and forgot the solution;
The error is on select ; drawing a select box on a parcel only results
in text "./select.map"
If I remember correctly, previously I was missing some header for the
html files within landrecords. (selectfooter, header, parcel.html -
respectively)
my select.map
LAYER # Parcels Polygon Layer
NAME 'parcels'
DATA './landrecords/parcels.shp'
STATUS ON
TYPE POLYGON
METADATA
qstring_validation_pattern '.'
END
HEADER 'landrecords/select_header.html'
TEMPLATE 'landrecords/select_parcel.html'
FOOTER 'landrecords/select_footer.html'
TOLERANCE 0
CLASS
SYMBOL 'plainline'
SIZE 3
COLOR -1 -1 -1
OUTLINECOLOR 255 255 0
END
END
"If one advances confidently in the direction of his dreams, and
endeavors to live the life which he has imagined, he will meet with a
success unexpected in common hours." ~Thoreau
More information about the Geomoose-users
