[Geomoose-users] IE will not display identify results
Brent Fraser bfraser at geoanalytic.com
Tue Nov 24 12:34:00 EST 2009
Works on my site.
Thanks!
Brent
Len Kne wrote:
> Try changing the offending line from:
> if(inputs[i].type != 'hidden' ) {
> to:
> if(inputs[i].type != ('hidden' && 'radio')) {
> The Identify tool allows you to select the shape you want to draw
> (point, box, etc.) and there is a radio box to select which option.
> Radio boxes cannot get focus, so IE throws the error.
> Len
> *From:* Edward E. Boesenberg, III [mailto:eboesenberg at niraengineers.com]
> *Sent:* Tuesday, November 24, 2009 10:45 AM
> *To:* 'Dan Little'; 'Geomoose Support'
> *Subject:* Re: [Geomoose-users] IE will not display identify results
> I tested it with another client machine running IE7 and got the same
> result, nothing happened.
> *From:* Dan Little [mailto:danlittle at yahoo.com]
> *Sent:* Tuesday, November 24, 2009 11:36 AM
> *To:* Edward E. Boesenberg, III; Geomoose Support
> I will need to be writing a patch and setting up a testing environment.
> :-) I don't think any of my VM's are currently running IE8...
>     *From:* "Edward E. Boesenberg, III" <eboesenberg at niraengineers.com>
>     *To:* Dan Little <danlittle at yahoo.com>; Geomoose Support
>     <geomoose-users at lists.sourceforge.net>
>     *Sent:* Tue, November 24, 2009 10:35:13 AM
>     *Subject:* RE: [Geomoose-users] IE will not display identify results
>     Sorry,
>     IE8 and GM 2.0
>     *Sent:* Tuesday, November 24, 2009 11:26 AM
>     IE8? 2.0, 2.0.1, SVN-Trunk?
>         *To:* Geomoose Support <geomoose-users at lists.sourceforge.net>
>         *Sent:* Tue, November 24, 2009 10:26:34 AM
>         *Subject:* [Geomoose-users] IE will not display identify results
>         When I use the identify function in IE nothing happens but it
>         works fine if FF.  When I double click the yellow error sign I
>         get the error box with a message below.  It displays the map
>         fine.  Anyboby know how to fix this error?
>         Webpage error details
>         User Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 5.1;
>         Trident/4.0; .NET CLR 1.1.4322; .NET CLR 2.0.50727; .NET CLR
>         3.0.04506.30; .NET CLR 3.0.04506.648; .NET CLR 3.5.21022; .NET
>         CLR 3.0.4506.2152; .NET CLR 3.5.30729; MS-RTC LM 8)
>         Timestamp: Tue, 24 Nov 2009 16:24:46 UTC
>         Message: Can't move focus to the control because it is
>         invisible, not enabled, or of a type that does not accept the focus.
>         Line: 3496
>         Char: 5
>         Code: 0
>         URI: http://nira-server/geomoose2/compiled.js
>         Thanks,
>         CADD / GIS Manager
>         Nira Consulting Engineers, Inc.
>         950 Fifth Avenue
>         Coraopolis, PA 15108
>         www.niraengineers.com <http://www.niraengineers.com>
>         T: 412-262-3970
>         F: 412-262-1938
> Let Crystal Reports handle the reporting - Free Crystal Reports 2008 30-Day
> trial. Simplify your report design, integration and deployment - and focus on
> what you do best, core application coding. Discover what's new with
> Crystal Reports now.  http://p.sf.net/sfu/bobj-july
> Geomoose-users mailing list
> Geomoose-users at lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/geomoose-users
More information about the Geomoose-users mailing list
