[Geomoose-users] IE will not display identify results
    Edward E. Boesenberg, III
    eboesenberg at niraengineers.com
    Tue Nov 24 13:44:36 EST 2009
That cleared the error but it looks like I may have another problem with
showing results from identifying parcels.  I will test it a little more.
Sent: Tuesday, November 24, 2009 12:27 PM
To: 'Edward E. Boesenberg, III'; 'Dan Little'; 'Geomoose Support'
Subject: Re: [Geomoose-users] IE will not display identify results
Try changing the offending line from:
if(inputs[i].type != 'hidden' ) {
to:
if(inputs[i].type != ('hidden' && 'radio')) {
The Identify tool allows you to select the shape you want to draw (point,
box, etc.) and there is a radio box to select which option.  Radio boxes
cannot get focus, so IE throws the error.
Len
From: Edward E. Boesenberg, III [mailto:eboesenberg at niraengineers.com]
Sent: Tuesday, November 24, 2009 10:45 AM
To: 'Dan Little'; 'Geomoose Support'
I tested it with another client machine running IE7 and got the same result,
nothing happened.
Sent: Tuesday, November 24, 2009 11:36 AM
To: Edward E. Boesenberg, III; Geomoose Support
I will need to be writing a patch and setting up a testing environment. :-)
I don't think any of my VM's are currently running IE8...
From: "Edward E. Boesenberg, III" <eboesenberg at niraengineers.com>
To: Dan Little <danlittle at yahoo.com>; Geomoose Support
<geomoose-users at lists.sourceforge.net>
Sent: Tue, November 24, 2009 10:35:13 AM
Subject: RE: [Geomoose-users] IE will not display identify results
Sorry,
IE8 and GM 2.0
Sent: Tuesday, November 24, 2009 11:26 AM
IE8? 2.0, 2.0.1, SVN-Trunk?
To: Geomoose Support <geomoose-users at lists.sourceforge.net>
Sent: Tue, November 24, 2009 10:26:34 AM
Subject: [Geomoose-users] IE will not display identify results
When I use the identify function in IE nothing happens but it works fine if
FF.  When I double click the yellow error sign I get the error box with a
message below.  It displays the map fine.  Anyboby know how to fix this
error?
Webpage error details
User Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 5.1; Trident/4.0;
.NET CLR 1.1.4322; .NET CLR 2.0.50727; .NET CLR 3.0.04506.30; .NET CLR
3.0.04506.648; .NET CLR 3.5.21022; .NET CLR 3.0.4506.2152; .NET CLR
3.5.30729; MS-RTC LM 8)
Timestamp: Tue, 24 Nov 2009 16:24:46 UTC
Message: Can't move focus to the control because it is invisible, not
enabled, or of a type that does not accept the focus.
Line: 3496
Char: 5
Code: 0
URI: http://nira-server/geomoose2/compiled.js
Thanks,
CADD / GIS Manager
Nira Consulting Engineers, Inc.
950 Fifth Avenue
Coraopolis, PA 15108
www.niraengineers.com
T: 412-262-3970
F: 412-262-1938
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20091124/98b6e2d4/attachment.html
More information about the Geomoose-users
