[Geomoose-users] Scalebar image size problem
Dan Little
danlittle at yahoo.com
Tue Nov 24 14:49:15 EST 2009
The graphic scalebar doesn't work on a stock 2.0 setup. There are two reasons for this:
1) I just haven't tested the mapfile...
2) There's no way to turn off the "image buffer" or "guttering" that happens with OL unless you're using Trunk/2.2.
>From: "Edward E. Boesenberg, III" <eboesenberg at niraengineers.com>
>To: Geomoose Support <geomoose-users at lists.sourceforge.net>
>Sent: Tue, November 24, 2009 1:47:05 PM
>Subject: [Geomoose-users] Scalebar image size problem
>When I try and add the scale bar layer I get the pink screen.
>When I try and load the scalebar map file by URL I get an error about the image
>size.
>Is there a way to display a scale bar in GM2?
>Scalebar map File:
>MAP
> NAME 'scalebar'
> SIZE 800 650
> UNITS feet
> TRANSPARENT TRUE
> IMAGETYPE PNG
> WEB
> INCLUDE
>"../../temp_directory.map"
> END
> SCALEBAR
> INTERVALS 4
> STATUS EMBED
> STYLE 0
> OUTLINECOLOR 0 0 0
> POSITION LL
> UNITS feet
> BACKGROUNDCOLOR 200 200 200
> LABEL
> COLOR 0 0 0
> OUTLINECOLOR 200 200 200
> SIZE SMALL
> END
> END
>END
>CADD / GIS Manager
>Nira Consulting Engineers, Inc.
>950 Fifth Avenue
>Coraopolis, PA 15108
>www.niraengineers.com
>T: 412-262-3970
>F: 412-262-1938
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20091124/76c9f3dc/attachment.html
More information about the Geomoose-users
