[Geomoose-users] Scalebar image size problem
Edward E. Boesenberg, III eboesenberg at niraengineers.com
Tue Nov 24 15:13:52 EST 2009
No Problem, I will wait for 2.2.
Sent: Tuesday, November 24, 2009 2:49 PM
To: Edward E. Boesenberg, III; Geomoose Support
Subject: Re: [Geomoose-users] Scalebar image size problem
The graphic scalebar doesn't work on a stock 2.0 setup.  There are two
reasons for this:
1) I just haven't tested the mapfile...
2) There's no way to turn off the "image buffer" or "guttering" that happens
with OL unless you're using Trunk/2.2.
From: "Edward E. Boesenberg, III" <eboesenberg at niraengineers.com>
To: Geomoose Support <geomoose-users at lists.sourceforge.net>
Sent: Tue, November 24, 2009 1:47:05 PM
Subject: [Geomoose-users] Scalebar image size problem
When I try and add the scale bar layer I get the pink screen.  When I try
and load the scalebar map file by URL I get an error about the image size.
Is there a way to display a scale bar in GM2?
Scalebar map File:
MAP
                NAME 'scalebar'
                SIZE 800 650
                UNITS feet
                TRANSPARENT TRUE
                IMAGETYPE PNG
                WEB
                                INCLUDE "../../temp_directory.map"
                END
                SCALEBAR
                                INTERVALS 4
                                STATUS EMBED
                                STYLE 0
                                OUTLINECOLOR 0 0 0
                                POSITION LL
                                UNITS feet
                                BACKGROUNDCOLOR 200 200 200
                LABEL
                     COLOR    0 0 0
                     OUTLINECOLOR 200 200 200
                     SIZE     SMALL
                END
                END
END
CADD / GIS Manager
Nira Consulting Engineers, Inc.
950 Fifth Avenue
Coraopolis, PA 15108
www.niraengineers.com
T: 412-262-3970
F: 412-262-1938
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20091124/f9f613c5/attachment.html
More information about the Geomoose-users mailing list
