[Geomoose-users] Geomoose v1.6.1 select.map issue
    Brent Fraser
    bfraser at geoanalytic.com
    Wed Nov 25 10:54:30 EST 2009
The various browsers (and their versions) are quite sensitive to the formatting
of the text sent to them.
 From a post I made to the mailing list in June:
And by the way, it seems my formating problem was the
     print "<![CDATA[";
and
     print "]]>";
surrounding the print $template; in select.php.  Commenting those out restored
the formating and didn't seem to break the highlighting.
so you might try that.  But be sure to test in all the browsers you intend to
support.
Brent
t faustino wrote:
> SmartSniff is new to me - I'll download and give it shot. I keep
> getting what looks like CDATA problems when I view it in IE7
> On Wed, Nov 25, 2009 at 10:21 AM, Brent Fraser <bfraser at geoanalytic.com> wrote:
>> Was it working previously?
>> Has you done any editing in the select.php?  Did you use a HTTP sniffer like
>> SmartSniff to  view the conversation between GM and the server?
>> t faustino wrote:
>>> Sorry for double-post on this one but I'm desperate to get this resolved;
>>> My select.map is not highlighting selected parcels via select tool;
>>> works fine using itemquery function via Parcel searching.
>>> I'm not getting any error reads from Firefox - but parcels are not
>>> getting selected.
>>> In IE7 the parcel does select and provide info but does not highlight.
>>> Anyone with any helpful thoughts?
More information about the Geomoose-users
