[Geomoose-users] Geomoose v1.6.1 select.map issue
Brent Fraser
bfraser at geoanalytic.com
Wed Nov 25 11:08:32 EST 2009
Dan points out that there will be problems if you take out the CDATA tags; so
leave them in. But I expect the problem is in the formatting of the returned
template text. Create a very simple/minimal template and see if that works.
Brent
Brent Fraser wrote:
> The various browsers (and their versions) are quite sensitive to the formatting
> of the text sent to them.
> From a post I made to the mailing list in June:
> And by the way, it seems my formating problem was the
> print "<![CDATA[";
> and
> print "]]>";
> surrounding the print $template; in select.php. Commenting those out restored
> the formating and didn't seem to break the highlighting.
> so you might try that. But be sure to test in all the browsers you intend to
> support.
> Brent
> t faustino wrote:
>> SmartSniff is new to me - I'll download and give it shot. I keep
>> getting what looks like CDATA problems when I view it in IE7
>> On Wed, Nov 25, 2009 at 10:21 AM, Brent Fraser <bfraser at geoanalytic.com> wrote:
>>> Was it working previously?
>>> Has you done any editing in the select.php? Did you use a HTTP sniffer like
>>> SmartSniff to view the conversation between GM and the server?
>>> t faustino wrote:
>>>> Sorry for double-post on this one but I'm desperate to get this resolved;
>>>> My select.map is not highlighting selected parcels via select tool;
>>>> works fine using itemquery function via Parcel searching.
>>>> I'm not getting any error reads from Firefox - but parcels are not
>>>> getting selected.
>>>> In IE7 the parcel does select and provide info but does not highlight.
>>>> Anyone with any helpful thoughts?
> Let Crystal Reports handle the reporting - Free Crystal Reports 2008 30-Day
> trial. Simplify your report design, integration and deployment - and focus on
> what you do best, core application coding. Discover what's new with
> Crystal Reports now. http://p.sf.net/sfu/bobj-july
> Geomoose-users mailing list
> Geomoose-users at lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/geomoose-users
More information about the Geomoose-users
