[Geomoose-users] Reading font.list to use Truetype
FRANZ OKYERE
franzzoa at hotmail.com
Fri Nov 27 16:28:58 EST 2009
Hi all, Its worked finally! Its exactly what Brent suspected. I only changed the font.list to fontset.list and the labels are just following the road direction as expected . Appreciate that guys- i'm kinda elated.. I'll keep on though. Franz
> Date: Fri, 27 Nov 2009 10:52:53 -0700
> From: bfraser at geoanalytic.com
> To: franzzoa at hotmail.com
> CC: geomoose-users at lists.sourceforge.net
> Subject: Re: [Geomoose-users] Reading font.list to use Truetype
> Personally I doubt if it is a file permissions problem. More than likely is it
> a path name problem. Run Process Monitor
> (http://technet.microsoft.com/en-us/sysinternals/bb896645.aspx) on the server to
> see the paths to the files mapserver (or php) is trying to open.
> Or perhaps the error message is misleading and there is a syntax problem
> inside fontset.list.
> FRANZ OKYERE wrote:
> > I've changed that-was a typo. The problem still exist. The question is
> > how do I set file access to read the file? Obviously the font file is
> > not being read.
> >> Date: Fri, 27 Nov 2009 09:45:54 -0700
> >> Usually it is called fontset.list (not .lists), or if you have an older
> >> mapserver installation, fonts.list.
> >> FRANZ OKYERE wrote:
> >> > Hi in my efforts to get implement my curved labels I have also
> >> > discovered the following error even after reinstallation: msLoadFont():
> >> > Unable to access file. Error opening fontset
> >> > ..\.\fonts\font.lists. Any ideas as to what is giving this error,
> >> > because its the cause of my woes. The path to the fontset file is
> >> > perfect though. Franz Okyere. GIS specialist.
> >> > View your other email accounts from your Hotmail inbox. Add them now.
> >> > <http://clk.atdmt.com/UKM/go/186394592/direct/01/>
> >> > Let Crystal Reports handle the reporting - Free Crystal Reports 2008
> > 30-Day
> >> > trial. Simplify your report design, integration and deployment - and
> > focus on
> >> > what you do best, core application coding. Discover what's new with
> >> > Crystal Reports now. http://p.sf.net/sfu/bobj-july
> >> > _______________________________________________
> >> > Geomoose-users mailing list
> >> > Geomoose-users at lists.sourceforge.net
> >> > https://lists.sourceforge.net/lists/listinfo/geomoose-users
> > Let Crystal Reports handle the reporting - Free Crystal Reports 2008 30-Day
> > trial. Simplify your report design, integration and deployment - and focus on
_________________________________________________________________
Got more than one Hotmail account? Save time by linking them together
http://clk.atdmt.com/UKM/go/186394591/direct/01/
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20091127/355691c0/attachment.html
More information about the Geomoose-users
