[Geomoose-users] Parcel Report
Dan Little
danlittle at yahoo.com
Tue Sep 8 14:29:13 EDT 2009
Hi Matt,
It is working, however, the parcel report is meant to be run from GeoMOOSE, the XML is telling GeoMOOSE to open a new window with the resultant PDF.
>From: Matthew D. Syvertson <msyvertson at co.richland.nd.us>
>To: geomoose-users at lists.sourceforge.net
>Sent: Tuesday, September 8, 2009 1:26:26 PM
>Subject: Re: [Geomoose-users] Parcel Report
>All right. Ireceivea responsefrom Len Knewhich fixed the previousproblem, but now I havedifferentproblemexposed.
>1. The parcelreportURL is calledproperly, I think:http://localhost/geomoose2/php/feature_report.php?src=parcels/all&PIN_TXT=49-0001-04849.000
>2. The response is the following code:
> <results>
> <script><![CDATA[window.open("php/download.php?id=print_12524270094580&ext=pdf");]]></script>
> <html></html>
> </results>
>3. But I get the following error backin Firefox:
>This XML file does not appear to have any style information associated with it. The document tree is shown below.
>I have had this problem previously and cannot remember for sure what caused it. Any ideas?
>Matt Syvertson
>Richland County GIS Coordinator
>418 2nd Ave N
>Wahpeton, ND 58075
>Voice: 701-642-7860 Fax: 701-642-7746
>_____________________________________________
>From:Matthew D. Syvertson
>Sent:Friday, September 04, 2009 11:19 AM
>To:geomoose-users at lists.sourceforge.net
>Subject:Parcel Report
>Any idea what might be causing the following error that I am receiving when trying to print a parcel report?:
>Warning: [MapServer Error]: msDBFGetItemIndex(): Item 'PIN' not found. in C:\ms4w\apps\geomoose2\htdocs\php\feature_report.php on line 64 Warning: [MapServer Error]: msDrawMap(): Failed to draw layer named 'parcels'. in C:\ms4w\apps\geomoose2\htdocs\php\feature_report.php on line 96 Warning: [MapServer Error]: msDBFGetItemIndex(): Item 'PIN' not found. in C:\ms4w\apps\geomoose2\htdocs\php\feature_report.php on line 96 Warning: [MapServer Error]: msDBFGetItemIndex(): Item 'PIN' not found. in C:\ms4w\apps\geomoose2\htdocs\php\feature_report.php on line 96 Fatal error: Call to a member function saveImage() on a non-object in C:\ms4w\apps\geomoose2\htdocs\php\feature_report.php on line 101
>Thanks in advance.
>Matt Syvertson
>418 2nd Ave N
>Wahpeton, ND 58075
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20090908/1333d039/attachment.html
More information about the Geomoose-users
