[Geomoose-users] Geomoose2 and MapServer tolerance
Dan Little danlittle at yahoo.com
Mon Sep 14 16:00:36 EDT 2009
Hi Johan,
Is there any chance you can attach your mapfile for the effected layer?
Also, if UTM-15 is not the coordinate system you want to use you might want to check out:
http://www.geomoose.org/moose/docs/projections.html
It may make maintenance of your application easier over the long term.
----- Original Message ----
> From: Johan Forsman <Johan.Forsman at LA.GOV>
> To: "geomoose-users at lists.sourceforge.net" <geomoose-users at lists.sourceforge.net>
> Sent: Monday, September 14, 2009 2:55:01 PM
> Subject: [Geomoose-users] Geomoose2 and MapServer tolerance
> Hello All:
> Before I pester anyone with one of my many questions I wish to say "Thank You!"
> to the authors of Geomoose, OpenLayers, and MapServer. Discovering these
> products just recently I have been able to, in relatively short order and in
> spite of exceptionally weak programming skills, assemble a usable web mapping
> application for internal use in our state drinking-water program. This is really
> quite fantastic. I simply took the demo app included with Geomoose2 and adapted
> it (more or less successfully) to our needs. So far I have only needed to invest
> time and aspirin, a bargain by any measure.
> Now, on to question one of several thousands:
> Not counting the base map data, our data are mostly for water-well locations in
> point form. I have projected all data to NAD83 UTM15N using my desktop GIS
> application prior to uploading it for use with Mapserver.
> The identify tool works quite nicely, but I am having some issues with the
> tolerance. Specifically, it appears the tolerance is not recalculated when the
> scale changes. If I use ground units (meters) in my map file I would expect this
> to be the case, but if I use pixels I would expect the linear distance
> represented by one pixel to change depending on the scale.
> The map is 800x650, and maximum extent is at just under 1:3 million.
> If I use pixel units and a tolerance of 1, my back-of-envelope calculation
> estimates each pixel at ~850 meters or so. If I zoom in to 1:24000 and use the
> identify tool, it will still return every well in an ~850 meter radius. This
> becomes problematic.
> Using units of meters I can clearly be much more selective, but then on the
> other end of the scale I can't hit anything "just right" to obtain any results.
> If anyone can enlighten me I would be most grateful, and if I am missing
> something completely obvious and by this am wasting everyone's time, I apologize
> in advance.
> Respectfully,
> Johan.
> Johan Forsman, M.Sc.
> Geologist
> Safe Drinking Water Program
> Louisiana Department of Health and Hospitals
> Office of Public Health
> Telephone: 225.342.7309
> Telefax: 225.342.7303
> Let Crystal Reports handle the reporting - Free Crystal Reports 2008 30-Day
> trial. Simplify your report design, integration and deployment - and focus on
> what you do best, core application coding. Discover what's new with
> Crystal Reports now.  http://p.sf.net/sfu/bobj-july
> Geomoose-users mailing list
> Geomoose-users at lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/geomoose-users
More information about the Geomoose-users mailing list
