[Geomoose-users] Geomoose 2.0 first trial, UTM33 maps
g.stanca at tiscali.it
Wed Sep 16 04:55:57 EDT 2009
Hi everybody,
I'm really new to GeoMoose, and to MS4W, too, but I work
with GIS programs from 1997.
Now I'm triyng to create a first attempt
MapServer instance, containing data and shapes of Italy.
when I try to
modify the demo included in GeoMoose 2.0 for a projections =UTM33,
EPSGS32633 and the extrent of my Italia_basebap.map I obtain an empty
geomoose frame.
So, where am I wrong?
I add Italia_basemap.map for
reference
Thanks
Giuseppe Stancanelli
Italy
# Map file created from
QGIS project file ./PTCA/QGis/Italia_base.qgs
# Edit this file to
customize for your map interface
# (Created with PyQgis MapServer
Export plugin)
MAP
NAME italia_base
# Map image size
SIZE 800 600
UNITS meters
EXTENT -1036058.791421 3861358.479159 1677393.009512
5288053.891473
PROJECTION
"proj=utm"
"zone=33"
"ellps=WGS84"
"datum=WGS84"
"units=m"
"no_defs"
END
# Background color for the
map canvas -- change as desired
IMAGECOLOR 192 192 192
IMAGEQUALITY
95
IMAGETYPE gif
OUTPUTFORMAT
NAME gif
DRIVER 'GD/GIF'
MIMETYPE 'image/gif'
#IMAGEMODE PC256
EXTENSION 'gif'
END
Legend
LEGEND
IMAGECOLOR 255 255 255
STATUS ON
KEYSIZE
18 12
LABEL
TYPE BITMAP
SIZE MEDIUM
COLOR 0 0 89
END
END
# Web interface definition. Only the template
parameter
# is required to display a map. See MapServer documentation
WEB
# Set IMAGEPATH to the path where MapServer should
write its output.
IMAGEPATH '/tmp/'
# Set IMAGEURL to the url
that points to IMAGEPATH
# as defined in your web server
configuration
IMAGEURL '/tmp/'
# WMS server settings
METADATA
'wms_title' 'italia_base'
'wms_onlineresource' 'http://my.host.com/cgi-bin/mapserv?map=wms.map&'
'wms_srs' 'EPSG:4326'
END
#Scale range at
which web interface will operate
# Template and header/footer
settings
# Only the template parameter is required to display a
END
LAYER
NAME 'Italia'
TYPE POLYGON
DATA './PTCA/shape/italia.shp'
METADATA
'wms_title' 'Italia'
END
STATUS DEFAULT
TRANSPARENCY 100
PROJECTION
"proj=utm"
"zone=33"
"ellps=WGS84"
"datum=WGS84"
"units=m"
"no_defs"
END
CLASS
NAME 'Italia'
STYLE
SYMBOL 0
SIZE 2
OUTLINECOLOR 0 0 0
COLOR 144 50 207
END
END
END
LAYER
NAME
'Regioni'
TYPE POLYGON
DATA './PTCA/shape/regioni_utm.shp'
METADATA
'wms_title' 'Regioni'
END
STATUS DEFAULT
TRANSPARENCY 100
PROJECTION
"proj=utm"
"zone=33"
"ellps=WGS84"
"datum=WGS84"
"units=m"
"no_defs"
END
CLASS
NAME 'Regioni'
STYLE
SYMBOL 0
SIZE 2
OUTLINECOLOR 0 0 0
COLOR 150 123 90
END
END
END
LAYER
NAME 'Province'
TYPE POLYGON
DATA '.
/PTCA/shape/Province_utm.shp'
METADATA
'wms_title' 'Province'
END
STATUS DEFAULT
TRANSPARENCY 100
PROJECTION
"proj=utm"
"zone=33"
"ellps=WGS84"
"datum=WGS84"
"units=m"
"no_defs"
END
CLASS
NAME 'Province'
STYLE
SYMBOL 0
SIZE 2
OUTLINECOLOR 0 0 0
COLOR 229 210 191
END
END
END
LAYER
NAME
'Comuni'
TYPE POLYGON
DATA './PTCA/shape/Comuni.shp'
METADATA
'wms_title' 'Comuni'
END
STATUS DEFAULT
TRANSPARENCY 100
PROJECTION
"proj=utm"
"zone=33"
"ellps=WGS84"
"datum=WGS84"
"units=m"
"no_defs"
END
CLASS
NAME 'Comuni'
STYLE
SYMBOL 0
SIZE 2
OUTLINECOLOR 0 0 0
COLOR 45 220 182
END
END
END
LAYER
NAME 'Strade principali'
TYPE LINE
DATA
'./PTCA/shape/strade_principali.shp'
METADATA
'wms_title'
'Strade principali'
END
STATUS DEFAULT
TRANSPARENCY 100
PROJECTION
"proj=utm"
"zone=33"
"ellps=WGS84"
"datum=WGS84"
"units=m"
"no_defs"
END
CLASS
STYLE
SYMBOL 0
SIZE 2
OUTLINECOLOR
131 78 4
COLOR 0 0 0
END
END
END
LAYER
NAME 'FFSS'
TYPE LINE
DATA './PTCA/shape/ffss.shp'
METADATA
'wms_title' 'FFSS'
END
STATUS DEFAULT
TRANSPARENCY
100
PROJECTION
"proj=utm"
"zone=33"
"ellps=WGS84"
"datum=WGS84"
"units=m"
"no_defs"
END
CLASS
NAME
'FFSS'
STYLE
SYMBOL 0
SIZE 2
OUTLINECOLOR 24 93 38
COLOR 0 0 0
END
END
END
END
Il mutuo? Online risparmi!
Confronta le offerte di 40 banche con tassi esclusivi. Consulenza gratuita ed indipendente.
http://finanza.tiscali.it/mutui.aspx
More information about the Geomoose-users
