[Geomoose-users] Geomoose 2.0 first trial, UTM33 maps
Dan Little
danlittle at yahoo.com
Wed Sep 16 09:48:41 EDT 2009
Hi Giuseppe,
Can you attach your mapbook.xml file?
----- Original Message ----
> From: "g.stanca at tiscali.it" <g.stanca at tiscali.it>
> To: geomoose-users at lists.sourceforge.net
> Sent: Wednesday, September 16, 2009 3:55:57 AM
> Subject: [Geomoose-users] Geomoose 2.0 first trial, UTM33 maps
> Hi everybody,
> I'm really new to GeoMoose, and to MS4W, too, but I work
> with GIS programs from 1997.
> Now I'm triyng to create a first attempt
> MapServer instance, containing data and shapes of Italy.
> when I try to
> modify the demo included in GeoMoose 2.0 for a projections =UTM33,
> EPSGS32633 and the extrent of my Italia_basebap.map I obtain an empty
> geomoose frame.
> So, where am I wrong?
> I add Italia_basemap.map for
> reference
> Thanks
> Giuseppe Stancanelli
> Italy
> # Map file created from
> QGIS project file ./PTCA/QGis/Italia_base.qgs
> # Edit this file to
> customize for your map interface
> # (Created with PyQgis MapServer
> Export plugin)
> MAP
> NAME italia_base
> # Map image size
> SIZE 800 600
> UNITS meters
> EXTENT -1036058.791421 3861358.479159 1677393.009512
> 5288053.891473
> PROJECTION
> "proj=utm"
> "zone=33"
> "ellps=WGS84"
> "datum=WGS84"
> "units=m"
> "no_defs"
> END
> # Background color for the
> map canvas -- change as desired
> IMAGECOLOR 192 192 192
> IMAGEQUALITY
> 95
> IMAGETYPE gif
> OUTPUTFORMAT
> NAME gif
> DRIVER 'GD/GIF'
> MIMETYPE 'image/gif'
> #IMAGEMODE PC256
> EXTENSION 'gif'
> END
> Legend
> LEGEND
> IMAGECOLOR 255 255 255
> STATUS ON
> KEYSIZE
> 18 12
> LABEL
> TYPE BITMAP
> SIZE MEDIUM
> COLOR 0 0 89
> END
> END
> # Web interface definition. Only the template
> parameter
> # is required to display a map. See MapServer documentation
> WEB
> # Set IMAGEPATH to the path where MapServer should
> write its output.
> IMAGEPATH '/tmp/'
> # Set IMAGEURL to the url
> that points to IMAGEPATH
> # as defined in your web server
> configuration
> IMAGEURL '/tmp/'
> # WMS server settings
> METADATA
> 'wms_title' 'italia_base'
> 'wms_onlineresource' 'http://my.host.com/cgi-bin/mapserv?map=wms.map&'
> 'wms_srs' 'EPSG:4326'
> END
> #Scale range at
> which web interface will operate
> # Template and header/footer
> settings
> # Only the template parameter is required to display a
> END
> LAYER
> NAME 'Italia'
> TYPE POLYGON
> DATA './PTCA/shape/italia.shp'
> METADATA
> 'wms_title' 'Italia'
> END
> STATUS DEFAULT
> TRANSPARENCY 100
> PROJECTION
> "proj=utm"
> "zone=33"
> "ellps=WGS84"
> "datum=WGS84"
> "units=m"
> "no_defs"
> END
> CLASS
> NAME 'Italia'
> STYLE
> SYMBOL 0
> SIZE 2
> OUTLINECOLOR 0 0 0
> COLOR 144 50 207
> END
> END
> END
> LAYER
> NAME
> 'Regioni'
> TYPE POLYGON
> DATA './PTCA/shape/regioni_utm.shp'
> METADATA
> 'wms_title' 'Regioni'
> END
> STATUS DEFAULT
> TRANSPARENCY 100
> PROJECTION
> "proj=utm"
> "zone=33"
> "ellps=WGS84"
> "datum=WGS84"
> "units=m"
> "no_defs"
> END
> CLASS
> NAME 'Regioni'
> STYLE
> SYMBOL 0
> SIZE 2
> OUTLINECOLOR 0 0 0
> COLOR 150 123 90
> END
> END
> END
> LAYER
> NAME 'Province'
> TYPE POLYGON
> DATA '.
> /PTCA/shape/Province_utm.shp'
> METADATA
> 'wms_title' 'Province'
> END
> STATUS DEFAULT
> TRANSPARENCY 100
> PROJECTION
> "proj=utm"
> "zone=33"
> "ellps=WGS84"
> "datum=WGS84"
> "units=m"
> "no_defs"
> END
> CLASS
> NAME 'Province'
> STYLE
> SYMBOL 0
> SIZE 2
> OUTLINECOLOR 0 0 0
> COLOR 229 210 191
> END
> END
> END
> LAYER
> NAME
> 'Comuni'
> TYPE POLYGON
> DATA './PTCA/shape/Comuni.shp'
> METADATA
> 'wms_title' 'Comuni'
> END
> STATUS DEFAULT
> TRANSPARENCY 100
> PROJECTION
> "proj=utm"
> "zone=33"
> "ellps=WGS84"
> "datum=WGS84"
> "units=m"
> "no_defs"
> END
> CLASS
> NAME 'Comuni'
> STYLE
> SYMBOL 0
> SIZE 2
> OUTLINECOLOR 0 0 0
> COLOR 45 220 182
> END
> END
> END
> LAYER
> NAME 'Strade principali'
> TYPE LINE
> DATA
> './PTCA/shape/strade_principali.shp'
> METADATA
> 'wms_title'
> 'Strade principali'
> END
> STATUS DEFAULT
> TRANSPARENCY 100
> PROJECTION
> "proj=utm"
> "zone=33"
> "ellps=WGS84"
> "datum=WGS84"
> "units=m"
> "no_defs"
> END
> CLASS
> STYLE
> SYMBOL 0
> SIZE 2
> OUTLINECOLOR
> 131 78 4
> COLOR 0 0 0
> END
> END
> END
> LAYER
> NAME 'FFSS'
> TYPE LINE
> DATA './PTCA/shape/ffss.shp'
> METADATA
> 'wms_title' 'FFSS'
> END
> STATUS DEFAULT
> TRANSPARENCY
> 100
> PROJECTION
> "proj=utm"
> "zone=33"
> "ellps=WGS84"
> "datum=WGS84"
> "units=m"
> "no_defs"
> END
> CLASS
> NAME
> 'FFSS'
> STYLE
> SYMBOL 0
> SIZE 2
> OUTLINECOLOR 24 93 38
> COLOR 0 0 0
> END
> END
> END
> END
> Il mutuo? Online risparmi!
> Confronta le offerte di 40 banche con tassi esclusivi. Consulenza gratuita ed
> indipendente.
> http://finanza.tiscali.it/mutui.aspx
> Come build with us! The BlackBerry® Developer Conference in SF, CA
> is the only developer event you need to attend this year. Jumpstart your
> developing skills, take BlackBerry mobile applications to market and stay
> ahead of the curve. Join us from November 9-12, 2009. Register now!
> http://p.sf.net/sfu/devconf
> Geomoose-users mailing list
> Geomoose-users at lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/geomoose-users
More information about the Geomoose-users
