[Geomoose-users] R: Re: R: RE: Geomoose 2.0 first trial, UTM33 maps
Len Kne lkne at houstoneng.com
Wed Sep 16 10:33:19 EDT 2009
In your mapbook, try putting commas between the values in max_extent and initial_extent.
Len
-----Original Message-----
From: g.stanca at tiscali.it [mailto:g.stanca at tiscali.it]
Sent: Wednesday, September 16, 2009 9:25 AM
To: geomoose-users at lists.sourceforge.net
Subject: [Geomoose-users] R: Re: R: RE: Geomoose 2.0 first trial, UTM33 maps
Yes, I'm sorry.
Do you need the actual shapefiles indicated in the map file?
I can send you a bigger zip, with a single layer "regioni", and the shapefile it maps. Could be a simpler startpoint.
The mapfile
was generated by Qgis, the projection in it is latlong, but the shapefile has a UTM33N projection. So i tried in my other files changing the projection definition as follows:
PROJECTION
	"proj=utm"
"zone=33"
	"ellps=WGS84"
	"datum=WGS84"
	"units=m"
	"no_defs"
END
Messaggio originale----
Da: danlittle at yahoo.com
Data: 16/09/2009 16.07
A: "g.stanca at tiscali.it"<g.stanca at tiscali.it>
Ogg: Re: [Geomoose-users]
Can you send it as an
attachment? That way I can test it out in my local installation.  When it's in-line the lines are made to be a fixed width and I can't do the proper testing.
Tutto Incluso Light: chiami e navighi senza limiti a soli 9,95 euro al mese. Gratis la Sim Tiscali Mobile con 25 euro di traffico! ATTIVA ORA
http://abbonati.tiscali.it/telefono-adsl/prodotti/tc/tuttoincluso_light/
More information about the Geomoose-users mailing list
