[Geomoose-users] R: RE: R: Re: R: RE: Geomoose 2.0 first trial,
UTM33 maps
g.stanca at tiscali.it
Wed Sep 16 10:54:12 EDT 2009
Yes, now the map loads, but it is, as before, centered on the USA
layers, using the limits values from my mapfile.
I can't understand how
to specify that I want to center my map on a UTM 33N layer.
Converting all my shapes in dd, latlong, wgs84 could be a solution?
Thanks
Giuseppe
----Messaggio originale----
Da: lkne at houstoneng.com
Data: 16/09/2009 16.33
A: "'g.stanca at tiscali.it'"<g.stanca at tiscali.it>,
"geomoose-users at lists.sourceforge.net"<geomoose-users at lists.sourceforge.
net>
Ogg: RE: [Geomoose-users] R: Re: R: RE: Geomoose 2.0 first
trial, UTM33 maps
In your mapbook, try putting commas between the
values in max_extent and initial_extent.
Len
-----Original
Message-----
From: g.stanca at tiscali.it [mailto:g.stanca at tiscali.it]
Sent: Wednesday, September 16, 2009 9:25 AM
To: geomoose-users at lists.
sourceforge.net
Subject: [Geomoose-users] R: Re: R: RE: Geomoose 2.0
first trial, UTM33 maps
Yes, I'm sorry.
Do you need the actual
shapefiles indicated in the map file?
I can send you a bigger zip, with
a single layer "regioni", and the shapefile it maps. Could be a simpler
startpoint.
The mapfile
was generated by Qgis, the projection in it is
latlong, but the shapefile has a UTM33N projection. So i tried in my
other files changing the projection definition as follows:
PROJECTION
"proj=utm"
"zone=33"
"ellps=WGS84"
"datum=WGS84"
"units=m"
"no_defs"
END
Da: danlittle at yahoo.com
Data: 16/09/2009 16.07
A: "g.stanca at tiscali.it"<g.stanca at tiscali.it>
Ogg: Re: [Geomoose-users]
R: RE: Geomoose 2.0 first trial, UTM33 maps
Can you send it as an
attachment? That way I can test it out in my
local installation. When it's in-line the lines are made to be a fixed
width and I can't do the proper testing.
Tutto Incluso Light:
chiami e navighi senza limiti a soli 9,95 euro al mese. Gratis la Sim
Tiscali Mobile con 25 euro di traffico! ATTIVA ORA
http://abbonati.
tiscali.it/telefono-adsl/prodotti/tc/tuttoincluso_light/
Tutto Incluso Light: chiami e navighi senza limiti a soli 9,95 euro al mese. Gratis la Sim Tiscali Mobile con 25 euro di traffico! ATTIVA ORA
http://abbonati.tiscali.it/telefono-adsl/prodotti/tc/tuttoincluso_light/
More information about the Geomoose-users
