[Geomoose-users] Minnesota shows up in Europe
Dan Little
danlittle at yahoo.com
Thu Apr 8 14:35:56 EDT 2010
Without a bit more of a visual it would be hard to give too much additional advice as to what is going on but have you verified that:
- All Mapfile/Mapserver-type services are set to use EPSG:900913
- There is no client-side reprojection happening (IE, if the <map-service...> tag has a "projection" attribute)
LOTS of variables to address here...
>From: Nayna Nayate <nayna.nayate at gis.leg.mn>
>To: "geomoose-users at lists.sourceforge.net" <geomoose-users at lists.sourceforge.net>
>Sent: Thu, April 8, 2010 1:13:14 PM
>Subject: [Geomoose-users] Minnesota shows up in Europe
>I’ve added the google maps layers using the documentation on
>the geomoose websiteto my web application.
>The good news is that google services show up, bad news is that Minnesota shows
>up in Europe. I’m sure this is an issue with the projection but I don’t know
>where to fix it. I have both projection files in geomoose.html and in the
>project libraries.
><script type="text/javascript"
>src="./proj4js/lib/defs/EPSG26915.js"></script>
>src="./proj4js/lib/defs/EPSG900913.js"></script>
>Am I missing something obvious?
>Thanks
>Nayna
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20100408/b21795bf/attachment.html
More information about the Geomoose-users
