[Geomoose-users] Map Layer Order
Dan Little
danlittle at yahoo.com
Fri Apr 30 13:52:09 EDT 2010
The other way to fix that is to use the Mapfile as a WMS service. Then the URL controls the layer drawing order (which GeoMOOSE can manipulate).
>From: Len Kne <lkne at houstoneng.com>
>To: Dave Misun <dmisun at kapur-assoc.com>; "geomoose-users at lists.sourceforge.net" <geomoose-users at lists.sourceforge.net>
>Sent: Fri, April 30, 2010 12:21:22 PM
>Subject: Re: [Geomoose-users] Map Layer Order
>Hi Dave
>Try moving MH below the sewer line layer in the MAP file.
>Normally GeoMOOSE will order layers in the same order as the <map-source>,
>but when more than one layer in a map-source point to the same MAP file, the
>order is controlled by the MAP file, which is first in first out.
>Len
>From:Dave Misun
>[mailto:dmisun at kapur-assoc.com]
>Sent: Friday, April 30, 2010 11:02 AM
>To: 'geomoose-users at lists.sourceforge.net'
>Subject: [Geomoose-users] Map Layer Order
>Hello
>Everyone,
>I
>have a question about layer order on a map, searched the user list and
>didn't find any previous threads covering this. I have a sewer manhole
>point layer and a sewer pipe line layer, among others on my map, and the
>line layer is rendering on top of the point layer. I have the point layer on
>top of the list in the catalog & map service sections of MAPBOOK, as well
>as having MH come before pipes in my MAP file, but the pipes continue to render
>on top of the MHs; all else is correct. What am I overlooking?
>I'm
>using GM 2.2.
>Any
>advice is appreciated. Thanks!
>Dave Misun
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20100430/66c58c57/attachment.html
More information about the Geomoose-users
