[Geomoose-users] Map Layer Order
Bob Basques
Bob.Basques at ci.stpaul.mn.us
Fri Apr 30 13:53:16 EDT 2010
All,
You might look into setting up a common mapfile for both points and lines, where the Sewers come on in a single layer call. There are pluses and minuses to this approach, but it does work.
bobb
>>> Len Kne <lkne at houstoneng.com> wrote:
Hi Dave
Try moving MH below the sewer line layer in the MAP file. Normally GeoMOOSE will order layers in the same order as the <map-source>, but when more than one layer in a map-source point to the same MAP file, the order is controlled by the MAP file, which is first in first out.
Len
Dave Misun [mailto:dmisun at kapur-assoc.com]
Sent: Friday, April 30, 2010 11:02 AM
To: 'geomoose-users at lists.sourceforge.net'
Subject: [Geomoose-users] Map Layer Order
Hello Everyone,
I have a question about layer order on a map, searched the user list and didn't find any previous threads covering this. I have a sewer manhole point layer and a sewer pipe line layer, among others on my map, and the line layer is rendering on top of the point layer. I have the point layer on top of the list in the catalog & map service sections of MAPBOOK, as well as having MH come before pipes in my MAP file, but the pipes continue to render on top of the MHs; all else is correct. What am I overlooking?
I'm using GM 2.2.
Any advice is appreciated. Thanks!
Dave Misun
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20100430/580a0956/attachment.html
More information about the Geomoose-users
