[Geomoose-users] Multiple sites sharing the same Geomoose code
Len Kne
lkne at houstoneng.com
Mon Dec 6 12:16:12 EST 2010
Hi Brent
We are doing something similar:
We use a session variable to set settings.ini, which in turn sets the Mapbook. See http://www.geomoose.org/wiki/index.php/Modification_to_Use_Multiple_Map_Books
Len
-----Original Message-----
From: Brent Fraser [mailto:bfraser at geoanalytic.com]
Sent: Monday, December 06, 2010 11:11 AM
To: Bob Basques
Cc: Geomooselist
Subject: [Geomoose-users] Multiple sites sharing the same Geomoose code
Bob (and others),
I've been thinking about enhancing GeoMoose to allow multiple "map sites" to share the same GeoMoose code, mostly to improve the ease of
maintenance. Rigth now I just copy the entire gemoose2 directory.
While that is expedient (and allows me to tweak parts of the GUI without fear of impacting other sites), I'm deferring an upgrade nightmare.
Instead of having geomoose.html as the site url, my strategy is to have something like:
http://myserver/maps/php/geomoose_start.php?conf=site1
The geomoose_start.php script would set a SESSION variable for the ini file name:
$_SESSION['ini_file'] = '../../conf/'.$_REQUEST['conf'];
This would be used in config.php; so instead of the current:
$CONFIGURATION = parse_ini_file('../../conf/settings.ini');
it would be :
$CONFIGURATION = $_SESSION['ini_file'];
geomoose_start.php would also read and send the site html file (e.g.
site1_html.txt) to browser. i think those are the only changes I'd need to make...
FYI, the directory structure would be:
geomoose2
conf\
site1.ini
site1.xml
site2.ini
site2.xml
htdocs\
site1_html.txt
site2_html.txt
skins\site1\site.css (optional)
skins\site2\site.css (optional)
maps\
site1\
site2\
Your thoughts?
Best Regards,
Brent Fraser
What happens now with your Lotus Notes apps - do you make another costly
upgrade, or settle for being marooned without product support? Time to move
off Lotus Notes and onto the cloud with Force.com, apps are easier to build,
use, and manage than apps on traditional platforms. Sign up for the Lotus
Notes Migration Kit to learn more. http://p.sf.net/sfu/salesforce-d2d
Geomoose-users mailing list
Geomoose-users at lists.sourceforge.net
https://lists.sourceforge.net/lists/listinfo/geomoose-users
More information about the Geomoose-users
