[Geomoose-users] Scalebar & Measure
Johan Forsman
Johan.Forsman at LA.GOV
Fri Dec 17 10:04:16 EST 2010
All:
I just discovered this issue. After applying Brent's fix below the measure tool appears to return the correct values, but there are other remaining issues.
I am using the 900913 projection for all data.
1. The scale bar is off. 500 meters on the scale bar measures to 431 meters, or a factor of ~0.86. This is not a critical issue, but it would be "nice" if it measured the same.
2. The select feature, using By Point, is a very clever way to get all features within a certain radius of a point location. However this function will return a radius that is shorter by about the same amount as the scale bar. This is an important issue. I have attached 3 screenshots illustrating the problem.
The GM shot shows what is supposed to be a 1-mile radius, plus the new measurement (post-fix) to the most distant feature of interest.
The GE-EC shot shows the measured distance using an all-Google application.
The ArcGIS shot shows the actual size of a circle with an (presumably ArcGIS is authoritative) 1-mile radius in the same location. These data are in NAD83 UTM 15N.
I measured the scale factors on a 200 meter scale bar (1:6771) for my state (Louisiana) and found them to be about 0.86 at the northern extreme and 0.89 at the southern extreme.
Is there any way I can implement some type of automatic correction to the select tool, and any other tool that may be affected by this behavior? Certainly I can inform the users that they need to add x % to their chosen buffer, but I am not prepared to trust the users to really do that.
Thanks!
/Johan.
> -----Original Message-----
> From: Brent Fraser [mailto:bfraser at geoanalytic.com]
> Sent: Wednesday, May 26, 2010 1:53 PM
> To: Len Kne
> Cc: 'geomoose-users at lists.sourceforge.net'
> Subject: Re: [Geomoose-users] Scalebar & Measure
> Len(and others interested in measuring),
> Here's my solution to the measure problem:
> In main.js somewhere around line 138 add the two lines below marked with a
> "//BWF":
> Tools['measure'] = new
> OpenLayers.Control.GeoMooseMeasure(OpenLayers.Handler.MeasurePath,
> measureToolOptions);
> Tools['measure'].geodesic = true; //BWF
> Tools['measurearea'] = new
> OpenLayers.Control.GeoMooseMeasure(OpenLayers.Handler.MeasurePolygon,
> Tools['measurearea'].geodesic = true; //BWF
> Thoughts?
> Brent
> Brent Fraser wrote:
> > Paul, Len,
> > Our scale problem is a (mostly) map projection issue. All map
> projections
> > introduce distortions in trying to represent a round(ish) Earth on a
> flat plane.
> > Mercator is no different: it is like wrapping an up-right cylinder
> around the
> > Earth, projecting light from the center onto the cylinder
> > (http://en.wikipedia.org/wiki/Mercator_projection). As you can imagine
> the
> > distortions get "worse" the further from the equator. The distortions
> can be
> > modeled as a Point Scale Factor. At the equator the Point Scale Factor
> is 1.0,
> > at latitude 60 degrees North (or South), the scale factor is 0.5!
> > So what's the solution? Here's mine:
> > 1. Enhance Proj4 (and Proj4js) to return the Point Scale factor
> (given the
> > projection and a location)
> > 2. Enhance MapServer and Openlayers to use the Point Scale Factor in
> > calculating distances and scale.
> > I'm trying to drum up interest, but so no takers....
> > http://osgeo-org.1803224.n2.nabble.com/Point-Scale-factor-service-
> td4938743.html
> > http://osgeo-org.1803224.n2.nabble.com/Re-3265-Scale-dependent-layer-
> switching-error-with-Mercator-td4966902.html
> > Best Regards,
> > Brent Fraser
> > Len Kne wrote:
> >> The scale bar issue with the web Mercator projection is a limitation of
> >> OpenLayers, the application GeoMOOSE 2.x uses to render the map frame.
> >> There has been discussion on the OpenLayers site about providing a
> >> patch (this link offers a patch http://trac.openlayers.org/ticket/1890
> >> in the next version 2.9. I'm sure GM will upgrade to OL 2.9, but not
> >> sure there is any schedule in place to do this.
> >> The cursor issue is also kind of fun because it seems each browser
> >> handles the custom icons differently. Here's the attribute in the
> >> mapbook which defines the query for the Identify service:
> >> cursor="url('cursors/identify2.cur') 9
> 9,url('cursors/identify2.cur'),auto"
> >> This makes three attempts to draw the cursor, the first offsets the
> >> mouse click 9 pixels from the top and the left. Firefox can use this
> >> value and seems to line the mouse click up pretty good with the
> >> crosshair. However, IE cannot handle the offset adjustment, so it
> reads
> >> the second cursor definition. There are tools like AT File Mole which
> >> can be used to edit the hotspot of a cursor. Attached is the latest
> >> version I have been using for Identify service, again this seems to
> line
> >> the crosshair up pretty well with the mouse click. If you are using
> >> Safari or Chrome, these setting don't seem to work at all and I would
> >> recommend not using customer cursors with those browsers.
> >> Len
> >> *From:* Wirth, Paul [mailto:Paul.Wirth at kniferiver.com]
> >> *Sent:* Saturday, May 01, 2010 9:03 PM
> >> *To:* 'geomoose-users at lists.sourceforge.net'
> >> *Subject:* [Geomoose-users] Scalebar & Measure
> >> Two questions:
> >> 1. I have a web Mercator application, and I noticed that the
> >> scalebar does not display the correct distance. For instance, when the
> >> scalebar shows a distance of 20 miles, it measures only 13.8 miles. I
> >> know the measure tools are working correctly, so I assume this is a
> >> scalebar issue. Any thoughts on how to fix this?
> >> 2. I think this question was asked before, but I can't seem to
> >> find it on the e-mail list. With the measure tools, the cursor does
> not
> >> start measuring at the "crosshairs" when the user clicks, but rather in
> >> the NW quadrant of the crosshairs. Is there a way to change it so the
> >> measure start point will be on the crosshairs?
> >> _______________________________________________
> >> Geomoose-users mailing list
> >> Geomoose-users at lists.sourceforge.net
> >> https://lists.sourceforge.net/lists/listinfo/geomoose-users
Type: image/png
Desc: ArcGIS_1mile.png
Url : http://lists.osgeo.org/pipermail/geomoose-users/attachments/20101217/5636f376/ArcGIS_1mile.png
Type: image/png
Desc: GEEC_1mile.png
Url : http://lists.osgeo.org/pipermail/geomoose-users/attachments/20101217/5636f376/GEEC_1mile.png
Type: image/png
Desc: GM_1mile.png
Url : http://lists.osgeo.org/pipermail/geomoose-users/attachments/20101217/5636f376/GM_1mile.png
More information about the Geomoose-users
