[Geomoose-users] getting started, running the demos question
Brent Fraser
bfraser at geoanalytic.com
Mon Jan 4 13:31:44 EST 2010
John,
MS4W documents the included software in the install notes
(http://www.maptools.org/ms4w/index.phtml?page=README_INSTALL_3.0.html) along
with some Troubleshooting notes.
If you can't use MS4W then you may be forced to compile Mapserver's PHP
Mapscript to ensure you get a version that's compatible with your installed
version of PHP. Other Mapserver users may be able to help with that...
Brent
John Callahan wrote:
> I wonder which version of PHP MS4W uses,
> http://windows.php.net/download/? The VC9 versions require the VC++
> 2008 package and seem to be improved from the VC6 versions. That page
> also states to NOT use the VC9 versions with apache.org
> <http://apache.org> binaries but use VC6 versions instead. Maybe MS4W
> compiles everything themselves to ensure compatibility?
> Just a note, not sure it matters, but I am a Windows user and never been
> able to use the MS4W package. I think MS4W is great but my servers
> usually already have Apache and PHP. I use MS4W to just get the
> MapServer/GDAL binaries. It's common from my experience for people to
> add web mapping apps/components (MapServer, GeoMoose, Google Maps,
> ArcIMS, etc...) to servers and sites that already exist in production.
> These servers/sites usually serve a number of other apps and cannot use
> the MS4W as is.
> So, for me, I need to find out exactly where I got my apache/php
> binaries from (on the server that will actualy house the GeoMoose app)
> and make sure mapserver/mapscript/geomoose components are compatible.
> - John
> On Mon, Jan 4, 2010 at 12:30 PM, Brent Fraser <bfraser at geoanalytic.com
> <mailto:bfraser at geoanalytic.com>> wrote:
> I just installed MS4W on a clean XP virtual machine. Apache would
> not start; I had to install the VC++ 2008 redist package
> (http://www.microsoft.com/downloads/details.aspx?familyid=9B2DA534-3E03-4391-8A4D-074B9F2BC1BF&displaylang=en
> <http://www.microsoft.com/downloads/details.aspx?familyid=9B2DA534-3E03-4391-8A4D-074B9F2BC1BF&displaylang=en>)
> Then it started and PHP reported:
> MapScript
> MapServer Version MapServer version 5.4.2 OUTPUT=GIF OUTPUT=PNG
> OUTPUT=JPEG OUTPUT=WBMP OUTPUT=PDF OUTPUT=SWF OUTPUT=SVG
> SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=ICONV
> SUPPORTS=FRIBIDI SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
> SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER
> SUPPORTS=SOS_SERVER SUPPORTS=FASTCGI SUPPORTS=THREADS SUPPORTS=GEOS
> SUPPORTS=RGBA_PNG INPUT=JPEG INPUT=POSTGIS INPUT=OGR INPUT=GDAL
> INPUT=SHAPEFILE
> PHP MapScript Version ($Revision: 9099 $ $Date: 2009-06-09 00:39:18
> -0300 (Tue, 09 Jun 2009) $)
> so I'm encouraged. I'll try GM next...
> Brent
> Brian Fischer wrote:
> I really haven’t tested MS4W 3.0 beta 7 with GM yet. I tried
> when it was in beta 2 and ran into some of these same problems.
> I would suggest if there are specific things we need added to
> MS4W to make things work with GM 2.2 we submit a bug. Kind of
> like the Mapbender project did in this bug
> http://bugzilla.maptools.org/show_bug.cgi?id=2086. Then if it
> is not to hard for them to add they will do it.
> Is the dbase .dll the only thing? I think when GM 2.2 comes out
> we need to explain the quirks of the dl() function.
> *Brian Fischer,* CFM GIS Project Manager
> *Houston Engineering, Inc.*
> Phone: W: 763.493.4522 / M: 763.229.2734
> *From:* Dan Little [mailto:danlittle at yahoo.com
> <mailto:danlittle at yahoo.com>]
> *Sent:* Monday, January 04, 2010 10:05 AM
> *To:* John Callahan
> *Cc:* GeoMOOSE Users List
> *Subject:* Re: [Geomoose-users] getting started, running the
> demos question
> We will probably not delay 2.2 in order to be PHP 5.3 ready. I
> would expect that if we're going to focus on PHP 5.3/MS4W 3.0
> then we're going to need to rollout a 2.2.(1/2/5) that subsumes
> it as a "bug fix."
> *From:* John Callahan <john.callahan at udel.edu
> <mailto:john.callahan at udel.edu>>
> *To:* Brent Fraser <bfraser at geoanalytic.com
> *Cc:* Dan Little <danlittle at yahoo.com
> <mailto:danlittle at yahoo.com>>;
> geomoose-users at lists.sourceforge.net
> <mailto:geomoose-users at lists.sourceforge.net>
> *Sent:* Mon, January 4, 2010 10:01:07 AM
> demos
> question
> Thanks Dan/Brent.
> Would you say that GeoMoose 2.2 would be tested/modified to work
> with MapServer 5.4.x and PHP 5.3 (and therefore MS4W 3.0 from a
> Windows perspective)? Actually, GM 2.2 could probably work
> for all
> MapServer 5.x versions....
> And that GeoMoose 2.0.x works with MapServer 5.2.x and PHP
> 5.2 (and
> therefore MS4W 2.3.x)?
> I wouldn't mind using GM 2.2 with PHP 5.2 (at least
> temporarily) if
> I can find a php_mapscript dll based on PHP 5.2 that works with
> MapServer 5.4.2.
> - John
> On Mon, Jan 4, 2010 at 10:39 AM, Brent Fraser
> <bfraser at geoanalytic.com <mailto:bfraser at geoanalytic.com>
> <mailto:bfraser at geoanalytic.com>>> wrote:
> Dan, John,
> I agree; we need to test GM 2.2 with MS4W 3.0. I'll have a
> look at
> the beta.
> I see that PHP's dl() is deprecated (due to security and
> threading
> issues), but the doc doesn't say what the replacement is (use the
> PHP.ini?). I think our plan would be to modify config.php to
> test
> if a module is loaded (as it does now) and just give a
> message if it
> isn't:
> if(!extension_loaded('gd') && !extension_loaded('gd2')) {
> printf( 'Please ensure the following extension is loaded
> using php.ini:'.'php_gd2.'.PHP_SHLIB_SUFFIX);
> Unless there's a better way?
> As for the php.dbase.dll, we could ask the MS4W people to
> include it...
> Best Regards,
> Brent Fraser
> Dan Little wrote:
> I think we simply need to do more testing on the more
> bleeding edge
> software. In some regard, we have enough issues keeping up with
> browser changes. Moving past developer excuses, I'm running
> OS/X
> 10.5.something and a few variants of debian and I believe
> they all
> have PHP 5.2, which is why there is probably some quirks when
> moving
> t o PHP 5.3.
> Brian/Len/Brent, any help on your versions? I just really
> don't use
> Windows for anything but running IE...
> <mailto:john.callahan at udel.edu <mailto:john.callahan at udel.edu>>>
> *To:* geomoose-users at lists.sourceforge.net
> <mailto:geomoose-users at lists.sourceforge.net>>
> *Sent:* Sun, January 3, 2010 8:31:42 AM
> < b>Subject: [Geomoose-users] getting started, running the
> demos
> question
> I'm trying to setup GeoMoose but ran into a problem that
> I'm not
> sure how to fix. After several hours of modifying my
> environment,
> here's where I'm at now:
> Windows OS
> Apache 2.2.11
> PHP 5.3.1 (VC6 x86 Thread Safe (2009-Nov-19 10:20:08) from
> http://windows.php.net/download/)
> MapServer 5.4.2 with PHP_MapScript from ms4w_3.0_beta7
> 2009-09-01
> GeoMoose from moose2-trunk as downloaded from the tarball
> as of Jan
> 1. ( I choose this over the 2.0.1 release because I liked
> some of
> the changes in 2.2.)
> Apparently, the php dl() function is now deprecated as of PHP
> 5.3. Even with the enable_dl set to 'On' in php.ini, it still
> throws an
> error when trying to run the demo. GeoMoose uses this
> function.
> How can I get around that?
> Also, I see GeoMoose uses php_dbase extension. That dll
> is not in
> the PHP or MS4W distributions I downloaded. I did see a
> php_ogr dll
> in MW4W though. How can I get around this?
> Lastly, I tried using php 5.2.8 and I WAS able to get the
> GeoMoose
> demo mostly working. However, some problems were
> occurring, likely
> because I didn't have php_mapscript, or maybe a wrong
> version. I
> switched to php 5.3 because I couldn't find a
> php_mapscript for
> MapServer 5.4.2 for p hp 5.2.x and because it was what MS4W
> currently supports.
> Thanks for any help or thoughts.
> - John
> John Callahan, Geospatial Application Developer
> Delaware Geological Survey, University of Delaware
> URL: http://www.dgs.udel.edu
> This SF.Net email is sponsored by the Verizon Developer Community
> Take advantage of Verizon's best-in-class app development support
> A streamlined, 14 day to market process makes app
> distribution fast
> and easy
> Join now and get one step closer to millions of Verizon customers
> http://p.sf.net/sfu/verizon-dev2dev
> Geomoose-users mailing list
> Geomoose-users at lists.sourceforge.net
> <mailto:Geomoose-users at lists.sourceforge.net>
> <mailto:Geomoose-users at lists.sourceforge.net>>
> https://lists.sourceforge.net/lists/listinfo/geomoose-users
> A streamlined, 14 day to market process makes app distribution
> fast and easy
More information about the Geomoose-users
