[Geomoose-users] getting started, running the demos question
Dan Little danlittle at yahoo.com
Tue Jan 5 15:14:59 EST 2010
Oh I know OGR can do it, it's a matter of whether or not there are PHP binding that make those capabilities useful.
>From: John Callahan <john.callahan at udel.edu>
>To: bfraser at geoanalytic.com
>Cc: Dan Little <danlittle at yahoo.com>; GeoMOOSE Users List <geomoose-users at lists.sourceforge.net>
>Sent: Tue, January 5, 2010 2:12:20 PM
>Subject: Re: [Geomoose-users] getting started, running the demos question
>It also looks like OGR can create simple DBF files by using the ESRI Shapefile driver and specifying the SHPT option as null.  Haven't tried it though.
>http://www.gdal.org/ogr/drv_shapefile.html
>- John
>On Tue, Jan 5, 2010 at 3:03 PM, Brent Fraser <bfraser at geoanalytic.com> wrote:
>>>Looking at the file dates at
>>http://dl.maptools.org/dl/php_ogr/
>>>>makes me skeptical about binaries being available in a timely fashion...
>>>>But the source is included in gdal distribution (swig/php)
>>>>> I haven't used the OGR/PHP bindings, if they are reasonable then yes, but
>>>>> I *thought* OGR only did standard SWIG bindings (perl, python, ruby).
>>>>> ----- Original Message ----
>>>>>> From: Brent Fraser <bfraser at geoanalytic.com>
>>>>>> To: Dan Little <danlittle at yahoo.com>
>>>>>> Cc: GeoMOOSE Users List <geomoose-users at lists.sourceforge.net>
>>>>>> Sent: Tue, January 5, 2010 1:37:30 PM
>>>>>> question
>>>>>> Could we use OGR via PHP to create .dbf files?
>>>>>> > Yeah, this is a bit of a problem as we need to be able to create DBase
>>>>>> > files but the old module is no longer supported and the new one not
>>>>>> > release.
>>>>>> > Have I ever mentioned to this list how much I absolutely love PHP
>>>>>> and/or
>>>>>> > it's "mostly free" model?
>>>>>> >> From: Brent Fraser
>>>>>> >> To: John Callahan
>>>>>> >> Cc: GeoMOOSE Users List ; Brian
>>>>>> >> Fischer
>>>>>> >> Sent: Tue, January 5, 2010 1:05:37 PM
>>>>>> >> question
>>>>>> >> And of some interest, http://bugs.php.net/bug.php?id=49222, says:
>>>>>> >> "dbase is unmaintained and moved to PECL though its yet to have a
>>>>>> >> release
>>>>>> >> there."
>>>>>> >> So until a PHP 5.3 compatible version of php_dbase.dll shows up
>>>>>> there,
>>>>>> >> it looks
>>>>>> >> like some of GM v2.2 PHP functions (select, mailing labels) will not
>>>>>> >> work with
>>>>>> >> MS4w 3.0.
>>>>>> >> Brent Fraser wrote:
>>>>>> >> > I didn't edit the config.php.  All of the GM required PHP dlls are
>>>>>> >> loaded via
>>>>>> >> > the php.ini file, except for php_dbase.dll.  And since I don't have
>>>>>> >> that one
>>>>>> >> on
>>>>>> >> > my test system, I'm confused why the print.php didn't crash and
>>>>>> burn.
>>>>>> >> I only
>>>>>> >> > tested the print.php which doesn't actually use php_dbase.dll;
>>>>>> perhaps
>>>>>> >> the
>>>>>> >> dl()
>>>>>> >> > function is tolerant of files not being available (until a function
>>>>>> is
>>>>>> >> used).
>>>>>> >> > Brent
>>>>>> >> > John Callahan wrote:
>>>>>> >> >> That's good to hear.  Thanks Brent.   Did you also edit the
>>>>>> >> config.php
>>>>>> >> >> to get rid of the dl() calls? or the php_dbase.dll dependence
>>>>>> (which
>>>>>> >> I
>>>>>> >> >> couldn't find in the ms4w 3.0 beta distribution)?
>>>>>> >> >> - John
>>>>>> >> >> On Tue, Jan 5, 2010 at 1:12 PM, Brent Fraser
>>>>>> >> >> > wrote:
>>>>>> >> >>     GM 2.2 (from SVN) running on MS4W 3.0 beta works ok after I
>>>>>> >> edited the
>>>>>> >> >>     mapbook.xml (for things we need to change anyway for the 2.2
>>>>>> Beta
>>>>>> >> >>     release).
>>>>>> >> >>     Creation of PDF,HTML, and jpg documents for Printing using PHP
>>>>>> >> seems
>>>>>> >> >>     to work ok too.
>>>>>> >> >>     Brent
>>>>>> >> >>     Brent Fraser wrote:
>>>>>> >> >>     >  I just installed MS4W on a clean XP virtual machine.
>>>>>> Apache
>>>>>> >> would
>>>>>> >> >>     not start; I
>>>>>> >> >>     >  had to install the VC++ 2008 redist package
>>>>>> (http://www.microsoft.com/downloads/details.aspx?familyid=9B2DA534-3E03-4391-8A4D-074B9F2BC1BF&displaylang=en
>>>>>> >> >>     >  Then it started and PHP reported:
>>>>>> >> >>     >  MapScript
>>>>>> >> >>     >  MapServer Version  MapServer version 5.4.2 OUTPUT=GIF
>>>>>> >> OUTPUT=PNG
>>>>>> >> >>     OUTPUT=JPEG
>>>>>> >> >>     >  OUTPUT=WBMP OUTPUT=PDF OUTPUT=SWF OUTPUT=SVG SUPPORTS=PROJ
>>>>>> >> >>     SUPPORTS=AGG
>>>>>> >> >>     >  SUPPORTS=FREETYPE SUPPORTS=ICONV SUPPORTS=FRIBIDI
>>>>>> >> SUPPORTS=WMS_SERVER
>>>>>> >> >>     >  SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT
>>>>>> >> >>     SUPPORTS=WCS_SERVER
>>>>>> >> >>     >  SUPPORTS=SOS_SERVER SUPPORTS=FASTCGI SUPPORTS=THREADS
>>>>>> >> SUPPORTS=GEOS
>>>>>> >> >>     >  SUPPORTS=RGBA_PNG INPUT=JPEG INPUT=POSTGIS INPUT=OGR
>>>>>> >> INPUT=GDAL
>>>>>> >> >>     INPUT=SHAPEFILE
>>>>>> >> >>     >  PHP MapScript Version  ($Revision: 9099 $ $Date: 2009-06-09
>>>>>> >> >>     00:39:18 -0300 (Tue,
>>>>>> >> >>     >  09 Jun 2009) $)
>>>>>> >> >>     >  so I'm encouraged.  I'll try GM next...
>>>>>> >> >>     >  Brent
>>>>>> >> >>     >  Brian Fischer wrote:
>>>> >> >>     > > I really haven’t tested MS4W 3.0 beta 7 with GM
>>>> yet.  I
>>>>>> >> tried when it
>>>>>> >> >>     > > was in beta 2 and ran into some of these same problems.
>>>>>> >> >>     > > I would suggest if there are specific things we need added
>>>>>> to
>>>>>> >> MS4W to
>>>>>> >> >>     > > make things work with GM 2.2 we submit a bug.  Kind of
>>>>>> like
>>>>>> >> the
>>>>>> >> >>     > > Mapbender project did in this bug
>>>>>> >> >>     > > http://bugzilla.maptools.org/show_bug.cgi?id=2086.  Then
>>>>>> if
>>>>>> >> it is
>>>>>> >> >>     not to
>>>>>> >> >>     > > hard for them to add they will do it.
>>>>>> >> >>     > > Is the dbase .dll the only thing?  I think when GM 2.2
>>>>>> comes
>>>>>> >> out
>>>>>> >> >>     we need
>>>>>> >> >>     > > to explain the quirks of the dl() function.
>>>>>> >> >>     > > *Brian Fischer,* CFM  GIS Project Manager
>>>>>> >> >>     > > *Houston Engineering, Inc.*
>>>>>> >> >>     > > Phone: W: 763.493.4522 / M: 763.229.2734
>>>>>> >> >>     > > *From:* Dan Little [mailto:danlittle at yahoo.com
>>>>>> >> >>     > > *Sent:* Monday, January 04, 2010 10:05 AM
>>>>>> >> >>     > > *To:* John Callahan
>>>>>> >> >>     > > *Cc:* GeoMOOSE Users List
>>>>>> >> >>     > > *Subject:* Re: [Geomoose-users] getting started, running
>>>>>> the
>>>>>> >> >>     demos question
>>>>>> >> >>     > > We will probably not delay 2.2 in order to be PHP 5.3
>>>>>> ready.
>>>>>> >> I would
>>>>>> >> >>     > > expect that if we're going to focus on PHP 5.3/MS4W 3.0
>>>>>> then
>>>>>> >> >>     we're going
>>>>>> >> >>     > > to need to rollout a 2.2.(1/2/5) that subsumes it as a
>>>>>> "bug
>>>>>> >> fix."
>>>>>> >> >>     > >     *From:* John Callahan
>>>>>> >> >>     > >     *To:* Brent Fraser
>>>>>> >> >>     > >     *Cc:* Dan Little
>>>>>> >> >>     > >     *Sent:* Mon, January 4, 2010 10:01:07 AM
>>>>>> running
>>>>>> >> the
>>>>>> >> >>     demos
>>>>>> >> >>     > >     question
>>>>>> >> >>     > >     Thanks Dan/Brent.
>>>>>> >> >>     > >     Would you say that GeoMoose 2.2 would be
>>>>>> tested/modified
>>>>>> >> to work
>>>>>> >> >>     > >     with MapServer 5.4.x and PHP 5.3 (and therefore MS4W
>>>>>> 3.0
>>>>>> >> from a
>>>>>> >> >>     > >     Windows perspective)?   Actually, GM 2.2 could
>>>>>> probably
>>>>>> >> work
>>>>>> >> >>     for all
>>>>>> >> >>     > >     MapServer 5.x versions....
>>>>>> >> >>     > >     And that GeoMoose 2.0.x works with MapServer 5.2.x and
>>>>>> >> PHP
>>>>>> >> >>     5.2 (and
>>>>>> >> >>     > >     therefore MS4W 2.3.x)?
>>>>>> >> >>     > >     I wouldn't mind using GM 2.2 with PHP 5.2 (at least
>>>>>> >> >>     temporarily) if
>>>>>> >> >>     > >     I can find a php_mapscript dll based on PHP 5.2 that
>>>>>> >> works with
>>>>>> >> >>     > >     MapServer 5.4.2.
>>>>>> >> >>     > >     - John
>>>>>> >> >>     > >     On Mon, Jan 4, 2010 at 10:39 AM, Brent Fraser
>>>>>> >> >>     wrote:
>>>>>> >> >>     > >     Dan, John,
>>>>>> >> >>     > >      I agree; we need to test GM 2.2 with MS4W 3.0.  I'll
>>>>>> >> have a
>>>>>> >> >>     look at
>>>>>> >> >>     > >     the beta.
>>>>>> >> >>     > >     I see that PHP's dl() is deprecated (due to security
>>>>>> and
>>>>>> >> >>     threading
>>>>>> >> >>     > >     issues), but the doc doesn't say what the replacement
>>>>>> is
>>>>>> >> (use the
>>>>>> >> >>     > >     PHP.ini?).  I think our plan would be to modify
>>>>>> >> config.php to
>>>>>> >> >>     test
>>>>>> >> >>     > >     if a module is loaded (as it does now) and just give a
>>>>>> >> >>     message if it
>>>>>> >> >>     > >     isn't:
>>>>>> >> >>     > >     if(!extension_loaded('gd') &&
>>>>>> !extension_loaded('gd2')) {
>>>>>> >> >>     > >            printf( 'Please ensure the following extension
>>>>>> is
>>>>>> >> loaded
>>>>>> >> >>     > >     using php.ini:'.'php_gd2.'.PHP_SHLIB_SUFFIX);
>>>>>> >> >>     > >     Unless there's a better way?
>>>>>> >> >>     > >     As for the php.dbase.dll, we could ask the MS4W people
>>>>>> to
>>>>>> >> >>     include it...
>>>>>> >> >>     > >     Best Regards,
>>>>>> >> >>     > >     Brent Fraser
>>>>>> >> >>     > >     Dan Little wrote:
>>>>>> >> >>     > >     I think we simply need to do more testing on the more
>>>>>> >> >>     bleeding edge
>>>>>> >> >>     > >     software.  In some regard, we have enough issues
>>>>>> keeping
>>>>>> >> up with
>>>>>> >> >>     > >     browser changes.  Moving past developer excuses,  I'm
>>>>>> >> running
>>>>>> >> >>     OS/X
>>>>>> >> >>     > >     10.5.something and a few variants of debian and I
>>>>>> believe
>>>>>> >> >>     they all
>>>>>> >> >>     > >     have PHP 5.2, which is why there is probably some
>>>>>> quirks
>>>>>> >> when
>>>>>> >> >>     moving
>>>>>> >> >>     > >     t o PHP 5.3.
>>>>>> >> >>     > >     Brian/Len/Brent, any help on your versions? I just
>>>>>> really
>>>>>> >> >>     don't use
>>>>>> >> >>     > >     Windows for anything but running IE...
>>>>>> >> >>     > >        *To:* geomoose-users at lists.sourceforge.net
>>>>>> >> >>     > >        *Sent:* Sun, January 3, 2010 8:31:42 AM
>>>>>> >> >>     > >        < b>Subject: [Geomoose-users] getting started,
>>>>>> running
>>>>>> >> the
>>>>>> >> >>     demos
>>>>>> >> >>     > >        question
>>>>>> >> >>     > >        I'm trying to setup GeoMoose but ran into a problem
>>>>>> >> that
>>>>>> >> >>     I'm not
>>>>>> >> >>     > >        sure how to fix.  After several hours of modifying
>>>>>> my
>>>>>> >> >>     environment,
>>>>>> >> >>     > >        here's where I'm at now:
>>>>>> >> >>     > >        Windows OS
>>>>>> >> >>     > >        Apache 2.2.11
>>>>>> >> >>     > >        PHP 5.3.1  (VC6 x86 Thread Safe (2009-Nov-19
>>>>>> 10:20:08)
>>>>>> >> from
>>>>>> >> >>     > >        http://windows.php.net/download/)
>>>>>> >> >>     > >        MapServer 5.4.2 with PHP_MapScript from
>>>>>> ms4w_3.0_beta7
>>>>>> >> >>     2009-09-01
>>>>>> (http://www.maptools.org/ms4w/index.phtml?page=README_INSTALL_3.0.html)
>>>>>> >> >>     > >        GeoMoose from moose2-trunk as downloaded from the
>>>>>> >> tarball
>>>>>> >> >>     as of Jan
>>>>>> >> >>     > >        1.  ( I choose this over the 2.0.1 release because
>>>>>> I
>>>>>> >> liked
>>>>>> >> >>     some of
>>>>>> >> >>     > >        the changes in 2.2.)
>>>>>> >> >>     > >        Apparently, the php dl() function is now deprecated
>>>>>> as
>>>>>> >> of PHP
>>>>>> >> >>     > >     5.3.    Even with the enable_dl set to 'On' in
>>>>>> php.ini,
>>>>>> >> it still
>>>>>> >> >>     > >     throws an
>>>>>> >> >>     > >        error when trying to run the demo.  GeoMoose uses
>>>>>> this
>>>>>> >> >>     function.
>>>>>> >> >>     > >        How can I get around that?
>>>>>> >> >>     > >        Also, I see GeoMoose uses php_dbase extension.
>>>>>> That
>>>>>> >> dll
>>>>>> >> >>     is not in
>>>>>> >> >>     > >        the PHP or MS4W distributions I downloaded.  I did
>>>>>> see
>>>>>> >> a
>>>>>> >> >>     php_ogr dll
>>>>>> >> >>     > >        in MW4W though.  How can I get around this?
>>>>>> >> >>     > >        Lastly, I tried using php 5.2.8 and I WAS able to
>>>>>> get
>>>>>> >> the
>>>>>> >> >>     GeoMoose
>>>>>> >> >>     > >        demo mostly working.  However, some problems were
>>>>>> >> >>     occurring, likely
>>>>>> >> >>     > >        because I didn't have php_mapscript, or maybe a
>>>>>> wrong
>>>>>> >> >>     version.  I
>>>>>> >> >>     > >        switched to php 5.3 because I couldn't find a
>>>>>> >> >>     php_mapscript for
>>>>>> >> >>     > >        MapServer 5.4.2 for p hp 5.2.x and because it was
>>>>>> what
>>>>>> >> MS4W
>>>>>> >> >>     > >        currently supports.
>>>>>> >> >>     > >        Thanks for any help or thoughts.
>>>>>> >> >>     > >        - John
>>>>>> >> >>     > >        John Callahan, Geospatial Application Developer
>>>>>> >> >>     > >        Delaware Geological Survey, University of Delaware
>>>>>> >> >>     > >        URL: http://www.dgs.udel.edu
>>>>>> >> >>     > >     This SF.Net email is sponsored by the Verizon
>>>>>> Developer
>>>>>> >> Community
>>>>>> >> >>     > >     Take advantage of Verizon's best-in-class app
>>>>>> development
>>>>>> >> support
>>>>>> >> >>     > >     A streamlined, 14 day to market process makes app
>>>>>> >> >>     distribution fast
>>>>>> >> >>     > >     and easy
>>>>>> >> >>     > >     Join now and get one step closer to millions of
>>>>>> Verizon
>>>>>> >> customers
>>>>>> >> >>     > >     http://p.sf.net/sfu/verizon-dev2dev
>>>>>> >> >>     > >     _______________________________________________
>>>>>> >> >>     > >     Geomoose-users mailing list
>>>>>> >> >>     > >    Geomoose-users at lists.sourceforge.net
>>>>>> >> >>     > >    https://lists.sourceforge.net/lists/listinfo/geomoose-users
>>>>>> >> >>     > > This SF.Net email is sponsored by the Verizon Developer
>>>>>> >> Community
>>>>>> >> >>     > > Take advantage of Verizon's best-in-class app development
>>>>>> >> support
>>>>>> >> distribution
>>>>>> >> >>     fast and easy
>>>>>> >> >>     > > Join now and get one step closer to millions of Verizon
>>>>>> >> customers
>>>>>> >> Community
>>>>>> >> support
>>>>>> distribution
>>>>>> >> >>     fast and easy
>>>>>> >> customers
>>>>>> Community
>>>>>> support
>>>>>> >> >>     A streamlined, 14 day to market process makes app distribution
>>>>>> >> fast
>>>>>> >> >>     and easy
>>>>>> customers
>>>>>> >> > This SF.Net email is sponsored by the Verizon Developer Community
>>>>>> >> > Take advantage of Verizon's best-in-class app development support
>>>>>> >> > A streamlined, 14 day to market process makes app distribution fast
>>>>>> >> and easy
>>>>>> >> > Join now and get one step closer to millions of Verizon customers
>>>>>> and
>>>>>> >> easy
>>>>A streamlined, 14 day to market process makes app distribution fast and easy
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20100105/427de085/attachment.html
More information about the Geomoose-users mailing list
