[Geomoose-users] getting started, running the demos question
Brent Fraser
bfraser at geoanalytic.com
Tue Jan 5 15:24:19 EST 2010
I've attached the write example. It doesn't look too bad (as long as it
works).
> Oh I know OGR can do it, it's a matter of whether or not there are PHP
> binding that make those capabilities useful.
>>From: John Callahan <john.callahan at udel.edu>
>>To: bfraser at geoanalytic.com
>>Cc: Dan Little <danlittle at yahoo.com>; GeoMOOSE Users List
>> <geomoose-users at lists.sourceforge.net>
>>Sent: Tue, January 5, 2010 2:12:20 PM
>>Subject: Re: [Geomoose-users] getting started, running the demos question
>>It also looks like OGR can create simple DBF files by using the ESRI
>> Shapefile driver and specifying the SHPT option as null. Haven't tried
>> it though.
>>http://www.gdal.org/ogr/drv_shapefile.html
>>- John
>>On Tue, Jan 5, 2010 at 3:03 PM, Brent Fraser <bfraser at geoanalytic.com>
>> wrote:
>>>>Looking at the file dates at
>>>http://dl.maptools.org/dl/php_ogr/
>>>>>makes me skeptical about binaries being available in a timely
>>>>> fashion...
>>>>>But the source is included in gdal distribution (swig/php)
>>>>>> I haven't used the OGR/PHP bindings, if they are reasonable then
>>>>>> yes, but
>>>>>> I *thought* OGR only did standard SWIG bindings (perl, python,
>>>>>> ruby).
>>>>>> ----- Original Message ----
>>>>>>> From: Brent Fraser <bfraser at geoanalytic.com>
>>>>>>> To: Dan Little <danlittle at yahoo.com>
>>>>>>> Cc: GeoMOOSE Users List <geomoose-users at lists.sourceforge.net>
>>>>>>> Sent: Tue, January 5, 2010 1:37:30 PM
>>>>>>> question
>>>>>>> Could we use OGR via PHP to create .dbf files?
>>>>>>> > Yeah, this is a bit of a problem as we need to be able to create
>>>>>>> DBase
>>>>>>> > files but the old module is no longer supported and the new one
>>>>>>> not
>>>>>>> > release.
>>>>>>> > Have I ever mentioned to this list how much I absolutely love PHP
>>>>>>> and/or
>>>>>>> > it's "mostly free" model?
>>>>>>> >> From: Brent Fraser
>>>>>>> >> To: John Callahan
>>>>>>> >> Cc: GeoMOOSE Users List ; Brian
>>>>>>> >> Fischer
>>>>>>> >> Sent: Tue, January 5, 2010 1:05:37 PM
>>>>>>> >> question
>>>>>>> >> And of some interest, http://bugs.php.net/bug.php?id=49222,
>>>>>>> says:
>>>>>>> >> "dbase is unmaintained and moved to PECL though its yet to have
>>>>>>> a
>>>>>>> >> release
>>>>>>> >> there."
>>>>>>> >> So until a PHP 5.3 compatible version of php_dbase.dll shows up
>>>>>>> there,
>>>>>>> >> it looks
>>>>>>> >> like some of GM v2.2 PHP functions (select, mailing labels) will
>>>>>>> not
>>>>>>> >> work with
>>>>>>> >> MS4w 3.0.
>>>>>>> >> Brent Fraser wrote:
>>>>>>> >> > I didn't edit the config.php. All of the GM required PHP dlls
>>>>>>> are
>>>>>>> >> loaded via
>>>>>>> >> > the php.ini file, except for php_dbase.dll. And since I don't
>>>>>>> have
>>>>>>> >> that one
>>>>>>> >> on
>>>>>>> >> > my test system, I'm confused why the print.php didn't crash
>>>>>>> and
>>>>>>> burn.
>>>>>>> >> I only
>>>>>>> >> > tested the print.php which doesn't actually use php_dbase.dll;
>>>>>>> perhaps
>>>>>>> >> the
>>>>>>> >> dl()
>>>>>>> >> > function is tolerant of files not being available (until a
>>>>>>> function
>>>>>>> is
>>>>>>> >> used).
>>>>>>> >> > Brent
>>>>>>> >> > John Callahan wrote:
>>>>>>> >> >> That's good to hear. Thanks Brent. Did you also edit the
>>>>>>> >> config.php
>>>>>>> >> >> to get rid of the dl() calls? or the php_dbase.dll dependence
>>>>>>> (which
>>>>>>> >> I
>>>>>>> >> >> couldn't find in the ms4w 3.0 beta distribution)?
>>>>>>> >> >> - John
>>>>>>> >> >> On Tue, Jan 5, 2010 at 1:12 PM, Brent Fraser
>>>>>>> >> >> > wrote:
>>>>>>> >> >> GM 2.2 (from SVN) running on MS4W 3.0 beta works ok after
>>>>>>> I
>>>>>>> >> edited the
>>>>>>> >> >> mapbook.xml (for things we need to change anyway for the
>>>>>>> 2.2
>>>>>>> Beta
>>>>>>> >> >> release).
>>>>>>> >> >> Creation of PDF,HTML, and jpg documents for Printing
>>>>>>> using PHP
>>>>>>> >> seems
>>>>>>> >> >> to work ok too.
>>>>>>> >> >> Brent
>>>>>>> >> >> Brent Fraser wrote:
>>>>>>> >> >> > I just installed MS4W on a clean XP virtual machine.
>>>>>>> Apache
>>>>>>> >> would
>>>>>>> >> >> not start; I
>>>>>>> >> >> > had to install the VC++ 2008 redist package
>>>>>>> (http://www.microsoft.com/downloads/details.aspx?familyid=9B2DA534-3E03-4391-8A4D-074B9F2BC1BF&displaylang=en
>>>>>>> >> >> > Then it started and PHP reported:
>>>>>>> >> >> > MapScript
>>>>>>> >> >> > MapServer Version MapServer version 5.4.2 OUTPUT=GIF
>>>>>>> >> OUTPUT=PNG
>>>>>>> >> >> OUTPUT=JPEG
>>>>>>> >> >> > OUTPUT=WBMP OUTPUT=PDF OUTPUT=SWF OUTPUT=SVG
>>>>>>> SUPPORTS=PROJ
>>>>>>> >> >> SUPPORTS=AGG
>>>>>>> >> >> > SUPPORTS=FREETYPE SUPPORTS=ICONV SUPPORTS=FRIBIDI
>>>>>>> >> SUPPORTS=WMS_SERVER
>>>>>>> >> >> > SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER
>>>>>>> SUPPORTS=WFS_CLIENT
>>>>>>> >> >> SUPPORTS=WCS_SERVER
>>>>>>> >> >> > SUPPORTS=SOS_SERVER SUPPORTS=FASTCGI SUPPORTS=THREADS
>>>>>>> >> SUPPORTS=GEOS
>>>>>>> >> >> > SUPPORTS=RGBA_PNG INPUT=JPEG INPUT=POSTGIS INPUT=OGR
>>>>>>> >> INPUT=GDAL
>>>>>>> >> >> INPUT=SHAPEFILE
>>>>>>> >> >> > PHP MapScript Version ($Revision: 9099 $ $Date:
>>>>>>> 2009-06-09
>>>>>>> >> >> 00:39:18 -0300 (Tue,
>>>>>>> >> >> > 09 Jun 2009) $)
>>>>>>> >> >> > so I'm encouraged. I'll try GM next...
>>>>>>> >> >> > Brent
>>>>>>> >> >> > Brian Fischer wrote:
>>>>> >> >> > > I really havenâââ‰â¢t tested MS4W 3.0 beta
>>>>> 7 with GM
>>>>> yet. I
>>>>>>> >> tried when it
>>>>>>> >> >> > > was in beta 2 and ran into some of these same
>>>>>>> problems.
>>>>>>> >> >> > > I would suggest if there are specific things we need
>>>>>>> added
>>>>>>> to
>>>>>>> >> MS4W to
>>>>>>> >> >> > > make things work with GM 2.2 we submit a bug. Kind
>>>>>>> of
>>>>>>> like
>>>>>>> >> the
>>>>>>> >> >> > > Mapbender project did in this bug
>>>>>>> >> >> > > http://bugzilla.maptools.org/show_bug.cgi?id=2086.
>>>>>>> Then
>>>>>>> if
>>>>>>> >> it is
>>>>>>> >> >> not to
>>>>>>> >> >> > > hard for them to add they will do it.
>>>>>>> >> >> > > Is the dbase .dll the only thing? I think when GM
>>>>>>> 2.2
>>>>>>> comes
>>>>>>> >> out
>>>>>>> >> >> we need
>>>>>>> >> >> > > to explain the quirks of the dl() function.
>>>>>>> >> >> > > *Brian Fischer,* CFM GIS Project Manager
>>>>>>> >> >> > > *Houston Engineering, Inc.*
>>>>>>> >> >> > > Phone: W: 763.493.4522 / M: 763.229.2734
>>>>>>> >> >> > > *From:* Dan Little [mailto:danlittle at yahoo.com
>>>>>>> >> >> > > *Sent:* Monday, January 04, 2010 10:05 AM
>>>>>>> >> >> > > *To:* John Callahan
>>>>>>> >> >> > > *Cc:* GeoMOOSE Users List
>>>>>>> >> >> > > *Subject:* Re: [Geomoose-users] getting started,
>>>>>>> running
>>>>>>> the
>>>>>>> >> >> demos question
>>>>>>> >> >> > > We will probably not delay 2.2 in order to be PHP 5.3
>>>>>>> ready.
>>>>>>> >> I would
>>>>>>> >> >> > > expect that if we're going to focus on PHP 5.3/MS4W
>>>>>>> 3.0
>>>>>>> then
>>>>>>> >> >> we're going
>>>>>>> >> >> > > to need to rollout a 2.2.(1/2/5) that subsumes it as
>>>>>>> a
>>>>>>> "bug
>>>>>>> >> fix."
>>>>>>> >> >> > > *From:* John Callahan
>>>>>>> >> >> > > *To:* Brent Fraser
>>>>>>> >> >> > > *Cc:* Dan Little
>>>>>>> >> >> > > *Sent:* Mon, January 4, 2010 10:01:07 AM
>>>>>>> running
>>>>>>> >> the
>>>>>>> >> >> demos
>>>>>>> >> >> > > question
>>>>>>> >> >> > > Thanks Dan/Brent.
>>>>>>> >> >> > > Would you say that GeoMoose 2.2 would be
>>>>>>> tested/modified
>>>>>>> >> to work
>>>>>>> >> >> > > with MapServer 5.4.x and PHP 5.3 (and therefore
>>>>>>> MS4W
>>>>>>> 3.0
>>>>>>> >> from a
>>>>>>> >> >> > > Windows perspective)? Actually, GM 2.2 could
>>>>>>> probably
>>>>>>> >> work
>>>>>>> >> >> for all
>>>>>>> >> >> > > MapServer 5.x versions....
>>>>>>> >> >> > > And that GeoMoose 2.0.x works with MapServer
>>>>>>> 5.2.x and
>>>>>>> >> PHP
>>>>>>> >> >> 5.2 (and
>>>>>>> >> >> > > therefore MS4W 2.3.x)?
>>>>>>> >> >> > > I wouldn't mind using GM 2.2 with PHP 5.2 (at
>>>>>>> least
>>>>>>> >> >> temporarily) if
>>>>>>> >> >> > > I can find a php_mapscript dll based on PHP 5.2
>>>>>>> that
>>>>>>> >> works with
>>>>>>> >> >> > > MapServer 5.4.2.
>>>>>>> >> >> > > - John
>>>>>>> >> >> > > On Mon, Jan 4, 2010 at 10:39 AM, Brent Fraser
>>>>>>> >> >> wrote:
>>>>>>> >> >> > > Dan, John,
>>>>>>> >> >> > > I agree; we need to test GM 2.2 with MS4W 3.0.
>>>>>>> I'll
>>>>>>> >> have a
>>>>>>> >> >> look at
>>>>>>> >> >> > > the beta.
>>>>>>> >> >> > > I see that PHP's dl() is deprecated (due to
>>>>>>> security
>>>>>>> and
>>>>>>> >> >> threading
>>>>>>> >> >> > > issues), but the doc doesn't say what the
>>>>>>> replacement
>>>>>>> is
>>>>>>> >> (use the
>>>>>>> >> >> > > PHP.ini?). I think our plan would be to modify
>>>>>>> >> config.php to
>>>>>>> >> >> test
>>>>>>> >> >> > > if a module is loaded (as it does now) and just
>>>>>>> give a
>>>>>>> >> >> message if it
>>>>>>> >> >> > > isn't:
>>>>>>> >> >> > > if(!extension_loaded('gd') &&
>>>>>>> !extension_loaded('gd2')) {
>>>>>>> >> >> > > printf( 'Please ensure the following
>>>>>>> extension
>>>>>>> is
>>>>>>> >> loaded
>>>>>>> >> >> > > using php.ini:'.'php_gd2.'.PHP_SHLIB_SUFFIX);
>>>>>>> >> >> > > Unless there's a better way?
>>>>>>> >> >> > > As for the php.dbase.dll, we could ask the MS4W
>>>>>>> people
>>>>>>> to
>>>>>>> >> >> include it...
>>>>>>> >> >> > > Best Regards,
>>>>>>> >> >> > > Brent Fraser
>>>>>>> >> >> > > Dan Little wrote:
>>>>>>> >> >> > > I think we simply need to do more testing on the
>>>>>>> more
>>>>>>> >> >> bleeding edge
>>>>>>> >> >> > > software. In some regard, we have enough issues
>>>>>>> keeping
>>>>>>> >> up with
>>>>>>> >> >> > > browser changes. Moving past developer excuses,
>>>>>>> I'm
>>>>>>> >> running
>>>>>>> >> >> OS/X
>>>>>>> >> >> > > 10.5.something and a few variants of debian and I
>>>>>>> believe
>>>>>>> >> >> they all
>>>>>>> >> >> > > have PHP 5.2, which is why there is probably some
>>>>>>> quirks
>>>>>>> >> when
>>>>>>> >> >> moving
>>>>>>> >> >> > > t o PHP 5.3.
>>>>>>> >> >> > > Brian/Len/Brent, any help on your versions? I
>>>>>>> just
>>>>>>> really
>>>>>>> >> >> don't use
>>>>>>> >> >> > > Windows for anything but running IE...
>>>>>>> >> >> > > *To:* geomoose-users at lists.sourceforge.net
>>>>>>> >> >> > > *Sent:* Sun, January 3, 2010 8:31:42 AM
>>>>>>> >> >> > > < b>Subject: [Geomoose-users] getting started,
>>>>>>> running
>>>>>>> >> the
>>>>>>> >> >> demos
>>>>>>> >> >> > > question
>>>>>>> >> >> > > I'm trying to setup GeoMoose but ran into a
>>>>>>> problem
>>>>>>> >> that
>>>>>>> >> >> I'm not
>>>>>>> >> >> > > sure how to fix. After several hours of
>>>>>>> modifying
>>>>>>> my
>>>>>>> >> >> environment,
>>>>>>> >> >> > > here's where I'm at now:
>>>>>>> >> >> > > Windows OS
>>>>>>> >> >> > > Apache 2.2.11
>>>>>>> >> >> > > PHP 5.3.1 (VC6 x86 Thread Safe (2009-Nov-19
>>>>>>> 10:20:08)
>>>>>>> >> from
>>>>>>> >> >> > > http://windows.php.net/download/)
>>>>>>> >> >> > > MapServer 5.4.2 with PHP_MapScript from
>>>>>>> ms4w_3.0_beta7
>>>>>>> >> >> 2009-09-01
>>>>>>> (http://www.maptools.org/ms4w/index.phtml?page=README_INSTALL_3.0.html)
>>>>>>> >> >> > > GeoMoose from moose2-trunk as downloaded from
>>>>>>> the
>>>>>>> >> tarball
>>>>>>> >> >> as of Jan
>>>>>>> >> >> > > 1. ( I choose this over the 2.0.1 release
>>>>>>> because
>>>>>>> I
>>>>>>> >> liked
>>>>>>> >> >> some of
>>>>>>> >> >> > > the changes in 2.2.)
>>>>>>> >> >> > > Apparently, the php dl() function is now
>>>>>>> deprecated
>>>>>>> as
>>>>>>> >> of PHP
>>>>>>> >> >> > > 5.3. Even with the enable_dl set to 'On' in
>>>>>>> php.ini,
>>>>>>> >> it still
>>>>>>> >> >> > > throws an
>>>>>>> >> >> > > error when trying to run the demo. GeoMoose
>>>>>>> uses
>>>>>>> this
>>>>>>> >> >> function.
>>>>>>> >> >> > > How can I get around that?
>>>>>>> >> >> > > Also, I see GeoMoose uses php_dbase extension.
>>>>>>> That
>>>>>>> >> dll
>>>>>>> >> >> is not in
>>>>>>> >> >> > > the PHP or MS4W distributions I downloaded. I
>>>>>>> did
>>>>>>> see
>>>>>>> >> a
>>>>>>> >> >> php_ogr dll
>>>>>>> >> >> > > in MW4W though. How can I get around this?
>>>>>>> >> >> > > Lastly, I tried using php 5.2.8 and I WAS able
>>>>>>> to
>>>>>>> get
>>>>>>> >> the
>>>>>>> >> >> GeoMoose
>>>>>>> >> >> > > demo mostly working. However, some problems
>>>>>>> were
>>>>>>> >> >> occurring, likely
>>>>>>> >> >> > > because I didn't have php_mapscript, or maybe
>>>>>>> a
>>>>>>> wrong
>>>>>>> >> >> version. I
>>>>>>> >> >> > > switched to php 5.3 because I couldn't find a
>>>>>>> >> >> php_mapscript for
>>>>>>> >> >> > > MapServer 5.4.2 for p hp 5.2.x and because it
>>>>>>> was
>>>>>>> what
>>>>>>> >> MS4W
>>>>>>> >> >> > > currently supports.
>>>>>>> >> >> > > Thanks for any help or thoughts.
>>>>>>> >> >> > > - John
>>>>>>> >> >> > > John Callahan, Geospatial Application
>>>>>>> Developer
>>>>>>> >> >> > > Delaware Geological Survey, University of
>>>>>>> Delaware
>>>>>>> >> >> > > URL: http://www.dgs.udel.edu
>>>>>>> >> >> > > This SF.Net email is sponsored by the Verizon
>>>>>>> Developer
>>>>>>> >> Community
>>>>>>> >> >> > > Take advantage of Verizon's best-in-class app
>>>>>>> development
>>>>>>> >> support
>>>>>>> >> >> > > A streamlined, 14 day to market process makes app
>>>>>>> >> >> distribution fast
>>>>>>> >> >> > > and easy
>>>>>>> >> >> > > Join now and get one step closer to millions of
>>>>>>> Verizon
>>>>>>> >> customers
>>>>>>> >> >> > > http://p.sf.net/sfu/verizon-dev2dev
>>>>>>> >> >> > > _______________________________________________
>>>>>>> >> >> > > Geomoose-users mailing list
>>>>>>> >> >> > > Geomoose-users at lists.sourceforge.net
>>>>>>> >> >> > > https://lists.sourceforge.net/lists/listinfo/geomoose-users
>>>>>>> >> >> > > John Callahan, Geospatial Application Developer
>>>>>>> Delaware
>>>>>>> Developer
>>>>>>> >> Community
>>>>>>> development
>>>>>>> >> support
>>>>>>> >> distribution
>>>>>>> >> >> fast and easy
>>>>>>> Verizon
>>>>>>> >> customers
>>>>>>> Developer
>>>>>>> >> Community
>>>>>>> development
>>>>>>> >> support
>>>>>>> distribution
>>>>>>> >> >> fast and easy
>>>>>>> Verizon
>>>>>>> >> customers
>>>>>>> >> >> This SF.Net email is sponsored by the Verizon Developer
>>>>>>> Community
>>>>>>> >> >> Take advantage of Verizon's best-in-class app development
>>>>>>> support
>>>>>>> distribution
>>>>>>> >> fast
>>>>>>> >> >> and easy
>>>>>>> >> >> Join now and get one step closer to millions of Verizon
>>>>>>> customers
>>>>>>> Community
>>>>>>> support
>>>>>>> >> > A streamlined, 14 day to market process makes app distribution
>>>>>>> fast
>>>>>>> >> and easy
>>>>>>> customers
>>>>>>> Community
>>>>>>> support
>>>>>>> fast
>>>>>>> and
>>>>>>> >> easy
>>>>>>> customers
>>>>>This SF.Net email is sponsored by the Verizon Developer Community
>>>>>Take advantage of Verizon's best-in-class app development support
>>>>>A streamlined, 14 day to market process makes app distribution fast
>>>>> and easy
>>>>>Join now and get one step closer to millions of Verizon customers
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/geomoose-users/attachments/20100105/bea3f19c/ogr_write.obj
More information about the Geomoose-users
