[Geomoose-users] Geomoose-users Digest, Vol 28, Issue 19
Mark Volz
MarkVolz at co.lyon.mn.us
Fri Jan 8 17:07:03 EST 2010
Jim,
Try adding
CONFIG "MS_ERRORFILE" "/ms4w/tmp/ms_tmp/ms_error.txt"
DEBUG 5
Right after "MAP" in your mapfile. It will create an error file in your temp
directory. Often it will indicate exactly what the problem is for example
it might be something dumb like its having trouble finding your
geomoose_globals.map file.
Mark Volz
GIS Specialist
Lyon County, MN
Message: 2
Date: Fri, 8 Jan 2010 15:55:00 -0600
From: Jim Hagedorn <jhagedorn at bannerassociates.com>
Subject: Re: [Geomoose-users] how to add aerial photo that isn't wms
To: Len Kne <lkne at houstoneng.com>
Cc: "'geomoose-users at lists.sourceforge.net'"
<geomoose-users at lists.sourceforge.net>
Message-ID:
<5863BC6EA0494C498F8C7A389EF32E493AA9452434 at BannerExg.banner.bannerbkgs.com>
Content-Type: text/plain; charset="utf-8"
Len
I did the changes that you have listed compared to the GM1.6 I was using. Is
there a difference in the mapbook?
This is what I have to call the raster:
<map-source name="photo_1" type="mapserver">
<file>./lcrws/Photos/photo_1.map</file>
</map-source>
<layer title="Segment 1" src="photo_1" status="off"/>
When I click on the selection box, nothing comes up in the status bar on the
bottom of the page like when you click on one of the layers.
Thanks
jim
Sent: Friday, January 08, 2010 3:27 PM
To: Jim Hagedorn
Cc: 'geomoose-users at lists.sourceforge.net'
Subject: RE: [Geomoose-users] how to add aerial photo that isn't wms
It should be the same as GM1.x. Here?s an example mapfile from one that
works on a site with GM2.
Len
MAP
NAME '2008_naip'
SIZE 800 650
STATUS on
EXTENT 2696719 505367 2805014 600572
UNITS FEET
INCLUDE "../geomoose_globals.map"
TRANSPARENT TRUE
IMAGETYPE JPEG
# SHAPEPATH ''
PROJECTION
"init=epsg:2288"
END
LAYER
NAME 'image'
DATA 'naip_2008_wi-spcz83ft_G2.sid'
STATUS ON
TYPE RASTER
END
END
From: Jim Hagedorn [mailto:jhagedorn at bannerassociates.com]
Sent: Friday, January 08, 2010 3:09 PM
To: Bob Basques; geomoose-users at lists.sourceforge.net
So this is something different in GM 2? Mr.sid?s worked in GM1.?.
Thanks
jim
From: Bob Basques [mailto:Bob.Basques at ci.stpaul.mn.us]
Sent: Friday, January 08, 2010 3:08 PM
To: Jim Hagedorn; geomoose-users at lists.sourceforge.net
Jim,
You'll need a MapServer executable compiled with the MRSID support, once
that's in place, then you configure the connection to the MRsid format via
the MapFile. Be advised that MRSid files can be lacking in performance vs
other data formats.
bobb
>>> Jim Hagedorn <jhagedorn at bannerassociates.com> wrote:
I?m looking for an example on how to add aerial photo. The only example I
can find is for wms but the mr.sid file is on my server.
Thanks
jim
Jim Hagedorn
GIS Specialist
[cid:image001.gif at 01CA907A.EF07DC00]
Banner Associates, Inc.
409 22nd Avenue South
PO Box 298
Brookings, South Dakota 57006
(605) 692-6342
Fax
(605) 692-5714
www.bannerassociates.com
Type: image/gif
Desc: image001.gif
This SF.Net email is sponsored by the Verizon Developer Community
Take advantage of Verizon's best-in-class app development support
A streamlined, 14 day to market process makes app distribution fast and easy
Join now and get one step closer to millions of Verizon customers
http://p.sf.net/sfu/verizon-dev2dev
Geomoose-users mailing list
Geomoose-users at lists.sourceforge.net
https://lists.sourceforge.net/lists/listinfo/geomoose-users
End of Geomoose-users Digest, Vol 28, Issue 19
More information about the Geomoose-users
