[Geomoose-users] identify tool
Efstathios Arapostathis e.arapostathis at gmail.com
Mon Jan 11 18:11:00 EST 2010
Hello
I'm sorry if I bother you, I sent again yesterday but I didn't get any
response.
I'm trying to make the identify option in the menu to work with a new layer
that I added. But I'm having some problems
Could someone help me with this?
Is there any document refering to how to configure identify tool in new
layers that are added?
I found only one in Geomoose 1.6 documentation but that document refers to
an identify.map file.
Does "identify_mylayer.html" need any different configuration than
"identify_parcel.html" that there is in the demo? (Except from replacing the
field names with the right ones).
Except from adding this code to tha map file:
METADATA
   'identify_record' 'identify_parcel.html'
END
Is any other configuration needed in order to run?
Thank you very much
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20100112/867f5ac6/attachment.html
More information about the Geomoose-users mailing list
