[Geomoose-users] identify tool
Brent Fraser
bfraser at geoanalytic.com
Mon Jan 11 23:40:01 EST 2010
It's difficult to tell what the problem is. Looking at the error from
your previous email,
Fatal error:
Call to a member function queryByPoint() on a non-object in
C:\ms4w\apps\museum_geomoose2\htdocs\php\identify.php on line 125
And since line 125 is
$map->queryByPoint($point, MS_MULTIPLE, -1);
, I'd expect there's either a problem with path of the map file, or a
syntax error in your map file. For some reason the $map object was not
created.
Best Regards,
Brent Fraser
> Hello
> I'm sorry if I bother you, I sent again yesterday but I didn't get any
> response.
> I'm trying to make the identify option in the menu to work with a new
> layer
> that I added. But I'm having some problems
> Could someone help me with this?
> Is there any document refering to how to configure identify tool in new
> layers that are added?
> I found only one in Geomoose 1.6 documentation but that document refers to
> an identify.map file.
> Does "identify_mylayer.html" need any different configuration than
> "identify_parcel.html" that there is in the demo? (Except from replacing
> the
> field names with the right ones).
> Except from adding this code to tha map file:
> METADATA
> 'identify_record' 'identify_parcel.html'
> END
> Is any other configuration needed in order to run?
> Thank you very much
> This SF.Net email is sponsored by the Verizon Developer Community
> Take advantage of Verizon's best-in-class app development support
> A streamlined, 14 day to market process makes app distribution fast and
> easy
> Join now and get one step closer to millions of Verizon customers
> http://p.sf.net/sfu/verizon-dev2dev
> Geomoose-users mailing list
> Geomoose-users at lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/geomoose-users
More information about the Geomoose-users
